Question about Logitech QuickCam Messenger Web Camera
Connection probleme: Everytime I try to install the driver for this WebCam it fails. The probleme acourding to the setup program is that it can`t see the WebCam. I`ve tried several USB ports and Windows picks it up everytime, but I can`t complete the installation from the driver, because it just keeps on telling me to connect the camera! Please help!
  • Anonymous Jan 16, 2009
    damn it
    Problem Solver:
  • 72 Answers
1. connect the camera.
2. when the pc identified the camera and recommended to locate the driver, select locate and install.
3. after instalation done, restart the pc.
Posted on Jan 04, 2008
6ya staff
SOURCE:
Everytime i try to use my webcam it tells me the driver isnt working but it wont accept any driver i try to download
Please remove the webcam and UNINSTALL THE DRIVER from the programs.
Now restart and log into the site to download once again the driver and download. Now Run the program and then CONNECT the webcam to be detected and installed as a new hardware.
Now the webcam must work or there are error in the PC, the webcam. Check the webcam with another PC to confirm.
Jun 30, 2011 | Computers & Internet
I am trying to install the dlink dcs 5220 camera, i have connected the camera to the router and the installation software has detected it. But everytime i click 'setup' all i get is a 'connection...
Welcome to Fixya
Try to uinstall and reinstall the software. Ping the camera if you are getting a reply. Reset the camera by pressing the small hole on the side. If everything is already done then same thing occur then you have a defective camera.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 17, 2011 | D-Link DCS-5220 Network Camera
Error during capture error code 800706f8
The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
windows-xp-other-device.jpg If the device is not recognized in Windows XP, it will be listed under Other Devices.
windows-vista-device-error.jpg In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the webcam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to uninstall the software that came with your webcam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party uninstaller.
After uninstalling the software, restart your PC and then reinstall the webcam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your webcam during the software installation.
If the drivers and webcam software are correctly installed, and you still cannot see any video, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the webcam feature. If you have multiple devices that qualify for video, you might need to select your webcam device as the source for the webcam feature in that program.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
Lastly, if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
video-capture-properties.jpg Do keep in mind that not all settings will be enabled depending on the webcam and the webcam driver installed on your computer. In the example you can see that some settings are disabled. The example shows the video capture properties for an Acer Crystal Eye webcam.
What else to try: download missing webcam drivers! If you are using your webcam for instant messaging with one of the popular chat programs, have a look at EatCam, which allows you to record your webcam chats from MSN, YM, ICQ, Skype, AIM and a few more!
Mar 05, 2011 | Computers & Internet
Message kb953691 as I download
If you are installing the software from the Web, and if the program stops responding (hangs), the program may be unable to connect to a server to download files. You must be connected to Internet to install the software. Depending on your Internet connection, the setup may take 15-20 minutes to finish.
You may notice that the installation process seems to get stuck in a loop, and seems to reinstall some components. This is typical behavior. However, if the setup stops or seems to get stuck in a loop for more 30 minutes, the server may be down or may be experiencing other problems. In this case, you may have to restart the setup, try again later, or try again the next day.
If the same thing happens, you can try the following steps :
Set Microsoft Internet Explorer as the default browser
loadTOCNode(2, 'resolution');
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. In the Internet Options dialog box, click to select Make Default on the Programs tab, and then click OK.
  4. Restart Internet Explorer.
  5. Click Yes if you are prompted with the following message: Internet Explorer is not currently your default browser. Would you like to make it your default browser?
  6. Exit Internet Explorer.
    Note You must complete these steps to install the software. After the install is complete, you can switch back to a different default browser if you prefer.
Jun 09, 2010 | Microsoft LifeCam VX-3000 Web Camera
Webcam driver open failed chicony 2.0
ur webcam driver is not suitable for win. 7
plz try it to install in program compatibilty mode
Nov 02, 2009 | Computers & Internet
Problem with my eye 312 camera
Assuming you are using Windows, did you check the Device Manager to see if the webcam device is working properly and has the right drivers installed?
Apart from that, try different programs, as not all programs support all devices. MSN and Yahoo messenger are good examples of that problem.
Some more tips on fixing webcam problems could also help.
Jul 31, 2009 | GE Computers & Internet
I cant see with my webcamera!
have you updated your dirvers? there could be a later version on the manurfactur's (soz bad s.p) website...
i had a logitech webcam that had to re-install the drivers everytime i unplugged it from the pc. i ended up getting a new webcam..
it also could be the programs skype and msn not reading the webcam when the other view program is open as it only works for one program @ a time....
Jul 05, 2009 | Microsoft LifeCam VX-1000 Webcam
Webcam setup on medion laptop
THE SOLUTION!!!!!!
1. Press start button.
2. In the "serch programs and files" tab typen in youcam. This will open up the webcam.
3. Once it is opened it will create a temporary icon on the task bar at the bottom of you desktop.
4. Click on this icon and you will have an option to pin it to the program to the taskbar, select this option and you will be able to easily start the launch of the program at any time.
Note: I really do not understand when Medion have not put direction for the webcam in the instruction manual!!!!!
Hope this helps,
Kathryn from London
Nov 16, 2008 | Computers & Internet
HP USB Webcam Problem
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Oct 20, 2008 | HP EW192AA Webcam
Webcam connection
hi, unplug the cam and uninstall its drivers & applications, reboot, then first install the drivers for the cam, then plug in the cam and assign the driver it has detected.
Impt.. when plugged in the USB the system should detect the cam, or else its faulty.. let me know
Mar 16, 2008 | Computers & Internet
Logitech QuickCam Messenger Web Camera Logo
50 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Alun Cox
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
