PC Laptops
Generic problem for all PC Laptops
D2d recovery
posted by nicolassp on Jan 04, 2008
i cannot run d2d recovery from aspire 5610 4648. I have tried to press alt+F10 during boot up screen, but it doesn't work. Also i couldn't find acer erecovery management in acer empowering management. Any idea how to run d2d recovery, or how to copy from its hidden partition?
I wiped my hdd but i have acer recovery dvds that i burned with e-recovery.When i am trying to restore my system with these disks nothing happens.Only a black screen says "Display error:string module not found".How can i recover my system and install e-recovery without saying not d2d system,e-recovery cannot install.Thanks in advance
Comment posted on Jan 04, 2008
My laptop is acer aspire 5920G
Comment posted on Jan 06, 2008
When i try to boot the recovery dvds i get a:display error string module not found.
D2d is enabled and when trying to press alt+f10 a black screen appears and asks me to enter boot commands
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Thanks for Trying (70)
mtspace
Rank:Wiz Wiz
Rating: 83%, 133 votes
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Rating Locked! (?) nicolassp has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on d2d recovery:
I don't want to Accept this solution
Solution #2
Not Rated (0)
cutejessie
Rank:Wiz Wiz
Rating: 78%, 45 votes
try to press f8 in boot up screen.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these PC Laptops problems?
Toshiba Satellite Pro A200-EZ2204X PC...
Key board of Toshiba Satellite A100-036 is stuck-up what...
Dell Latitude D505 PC Notebook
What does the red flashing icon mean that is 1 of 4...
Acer Aspire 3610 PC Notebook
hi i am a poopy
Toshiba Refurbished 730XCDT...
I inherited and know nothing at all about and would like...
Toshiba Satellite A105 PC Notebook
On my Toshiba satelite A105 I hit the monitor command and...
Loading problems.
Repair Service
Find PC Laptop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
