Thanks for using FixYa.
Dishwasher not draining properly or not draining at all issues can arise due
to different reasons. Usually, these issues are related to kinked hoses,
knocked out disposer unit (if connected with the dishwasher drain hose) &
clogged drain pump & filter.
Also note that dishwashers do not
drain completely after a finished cycle and this is normal. Dishwashers are
designed to leave some water in the unit to ensure that the heating element
doesn’t overheat. If you suddenly begin to experience a large amount of water
being retained in your dishwasher, you have a problem. Some of the most common
reasons include that the drain hose isn’t working properly, the drain pump
isn’t working correctly, or possibly there is a plumbing problem in your home’s
drain lines.
First check whether the drain is
not clogged or blocked and the line is not kinked. Check all the hoses for
blockages & also clean the air gap. Has the disposer been replaced
recently? If so, chances are the knockout is still in place. Simply remove the
drain hose from the disposer, and knock out the plug. If the disposer has not
been replaced, try removing the drain hose from the disposer and use a wet-dry
vacuum (prepared for water, of course) to **** any water (and hopefully anything
else) from the drain line. Then reconnect the hose, and test the unit. If you
have checked the air gap and the drain hose and can’t locate the problem, then
it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 17482 / 17484 /
I have a Kenmore Elite dishwasher and the under counter mounting hardware/bracket has broke. It...
(More)
I have a Kenmore Elite dishwasher and the under counter mounting hardware/bracket has broke. It seems that shops don't carry these parts. Is there a alternate fix for this problem?
I have a Kenmore Elite Dishwasher that is 3 yrs old, which cost $1000. On the top dish rack one of...
(More)
I have a Kenmore Elite Dishwasher that is 3 yrs old, which cost $1000. On the top dish rack one of the splines burst open, almost like it couldn't withstand the heat. I figured this would for sure be covered under the 5yr rack warranty, when I called they said it was but since it is 3yrs old the customer must pay the labor fee of $129. The rack itself only costs $104, and what labor is involved in pulling a rack out and putting a new one in? Does Kenmore not have a defective parts return center where you get an RMA number return your rack, once reviewed for warranty purposes they send you a new rack. I feel like I am being scammed out of money for a clearly defective part.
