unplug unit and let sit overnight, then try it again in the morning, if you moved the unit or laid it on its side all the compressor oil needs to settle back down
PCT starter. Inside starter there is a round disk, one side of the disk is down to metal.When I...
(More)
PCT starter. Inside starter there is a round disk, one side of the disk is down to metal.When I apply 120volts to compressor with statt on 3 I have 120V to ground on both term. of comp. Why did the starter go bad on one side?
Magic Chef Refridgerator, Model MCBR1010W, converting to Kegorator. Are there any coolant lines or...
(More)
Magic Chef Refridgerator, Model MCBR1010W, converting to Kegorator. Are there any coolant lines or wiring located in the right side panel, if so what are they and approx. location.
magic chef frige part is not getting cold and freezer part is over freezing what can i do to fix...
(More)
magic chef frige part is not getting cold and freezer part is over freezing what can i do to fix this?
My freezer compartment gets full of ice and drips. I would like to disconnect the freezer altogether...
(More)
My freezer compartment gets full of ice and drips. I would like to disconnect the freezer altogether since I don't need it. Is that possible? How?
