Adjusting I tried to adjust my tv, now there is a black box on the screen that covers 1/2 of the screen, and I can't get it off.
  • Anonymous Jan 05, 2008
    How to remove close captioning on model 07DG
    E 244239?
  • jwoodrow68 Feb 29, 2008
    Mitsubishi CS-35405 I have a black box that covers almost my entire screen. I no longer have the tv remote, just the remote for my cable box (comcast)
I had the same problem. the captions were on for two years till i read the above answer and its teh cc button that turns it off!!!!!!!
Posted on Mar 01, 2009
  • 3,130 Answers
You have the closed caption turned on the set. Since you did not leave a model number, I cannot tell you the procedure on how to turn it off. Sometimes there is a button on the remote marked CC or closed caption, and sometimes it is switched on and off through the on screen menu. Good Luck
Posted on Jan 04, 2008
How do I repair my LG LED TV, Model 55UF6430?
Please turn the closed caption off. you are on text 1 mode.
Aug 13, 2017 | LG Televison & Video
Blue line, blue out of sinc along botttom 1/4 of tv
If this is a Rear Projection T.V, your CRT is going bad. You can take the front cover off and make slight adjustments on the blue screen control to get rid of any lines, as far as the blurriness of blue, that part is 500 dollars to fix. The most you can do is just get rid of the lines. There's a black box. Make sure you are very gentle with your adjustments. Just turn it back to how it was if the screen shuts off. I recommend turning down the brightness of the T.V. before you do this repair.
Jun 18, 2011 | Panasonic Televison & Video
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Red horizontal curvy lines
You need to turn the voltage on the red tube down slightly, also you would need to adjust focus to compensate for the lower voltage to the red tube. On the left and right bottom side of speaker cover are two round covers, take them out and there are 2 1/4" hex screws take them out carefully take cover off, there is another service cover same hex screws remove. You will see the focus block on the right side, tubes are labled on block. 2 knobs for each tube. Make voltage adjustments while tv is on a black screen, then for focus, turn color all the way off in the menu, and adjust focus until it looks right in black and white. These adjustments should only be very small; if alot of adjustment is needed, you may have other issues.
May 29, 2009 | Sony KP-51WS500 51" Rear Projection...
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Red dots on my LG 42PX5D
Hello, you do not need to replace any of the sustain boards in your TV to fix the problem you are having. All you need to do is remove the back cover and make an adjustment to the Y sustain board. You will need to adjust the set_up & or the set_down! If you would like to do the adjustments to your TV please feel free to give me a call or message me. Ask for Dave! 1-503-432-9904 or message me @ You will need to remove the stand & the back cover. Then put the stand back on the TV so that you are able to set the TV in the up right position with the back cover off! Then you'll need to hook the TV up to a DVD player so that you are able to pause the picture while you are doing the adjustment to the Y sus! Do not adjust any other adjuster on the Y sus other then the SET_UP or the SET_DOWN. In order to identify the correct adjusters on the Ysus just look on the board and it should say SET_UP & SET_DOWN next to the correct adjusters. If you need more help please feel free to give me a call or message me!
Jan 12, 2009 | LG 42PX5D 42 in. Plasma HDTV
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Black box in the middle of my mitsubishi tv
This is a common problem, some how you have the closed caption on and turned to the text mode. So to fix this scoll through the tv's menu and find the closed caption and tur it back off
Mar 27, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
