Question about Canon imagePROGRAF iPF8000 Printer
Canon ipf8000 error code
Error code E161 403E appears which i believe is a printhead problem, but I cant access the printheads as with this code showing i cant access any menu or any other option
  • 3 more comments
  • Anonymous Mar 11, 2008
    i have a hartdware issue error code 03130031-2f26. what is causing this fault. machine does not work at all
  • MsVicky Sep 04, 2008
    Error code E161 403E appears which i believe is a printhead problem, but I cant access the printheads as with this code showing i cant access any menu or any other option. Can anyone help me?
  • mross001 Feb 11, 2009
    error E161-403E. Rebooting doesw not reset the plotter says to contact service.
  • milwaukee_dc Apr 05, 2009
    Canon iPF8000 plotter. Error E161-403F Call for Service. rebooting does not clear error.
  • basilis
    basilis May 16, 2017
    i have downGrade firmwares for IPF8100,IPF9100,IPF8000, IPF605,IPF700 UNLOCKS PRINT HEADS WHEN THE PLOTTER ASK YOU TO CHANGE THE HEADS. mail- a.louloudis1@gmail.com for questions and support
  • 3 Answers
Hold down the roll/media button and the info button while turning on, wait about 10 seconds and release roll/info buttons. You should get an S in the upper right corner. That puts you in service mode. Push menu then scroll down to maintenance then right arrow to head replacement. To get out of service mode turn off.
Posted on Jan 26, 2009
    Scholar:
  • 66 Answers
Go into service mode by holding the paper select and info button. turn on printer wait for an s to appear in the top right corner of the screen. let it continue to boot until it stops on its own even if it is another error. then turn off and reboot normal this time. If it still has the error E161 403E, then replace the head and do it again. This time go through the process to change the head, answering the questions the machine asks. If that doesnt resolve then change the carriage relay pcb. If that doesnt solve sell it kick yourself in the butt for buying the print head and the carriage relay pcb.
Posted on Dec 15, 2012
  • Ernest Taylor Dec 15, 2012
    I am sorry I put this reply in the wrong spot. I am actually working on error code 03130031-2f26 and will return my result fix.
  • basilis
    Sniper:
  • 79 Answers
Before replacing the print head try to update to the latest firmware.
Posted on Apr 13, 2009
I had this 03130031-2F26 problem - and 03130031-2F13, 03130031-4027 on my Canon ipf8000.
Problem was broke ribbon cable from carriage to mainboard. Tiny break just before the cables are glued before they go inside the machine.
Hope that helps!
Posted on May 21, 2011
"i have a hartdware issue error code 03130031-2f26. what is causing this fault. machine does not work at all"
This is the "Carriage cannot operate" error, we have got this problem in our plotter iPF710 and the canon`s support say us that this problem is the software`s problem. We wait the update for solvent this problem
Posted on Oct 10, 2008
E161 403E abnormal head temp , head needs replaced boot printer into service mode , and from the menu select replace print .
Posted on Apr 30, 2008
    Go into service mode by holding the paper select and info button. turn on printer wait for an s to appear in the top right corner of the screen. let it continue to boot until it stops on its own even if it is another error. then turn off and reboot normal this time. If it still has the error E161 403E, then replace the head and do it again. This time go through the process to change the head, answering the questions the machine asks. If that doesnt resolve then change the carriage relay pcb. If that doesnt solve sell it kick yourself in the ? for buying the print head and the carriage relay pcb.
  • basilis
When i started the ipf 8000, this error appears 031 30031 - 2 f 1 f
Posted on Feb 26, 2008
2 Suggested Answers
SOURCE: IPF8000 PLOTER
please input servicemode and reset all iniatilize menü
Posted on Dec 27, 2010
Error 03130031-2618 in canon ipf 750
Error code 03130031-2618 is a voltage error. It could happens on these printers models: IPF6350, IPF6300, IPF6000, IPF8000, IPF8300, etc...
Solution 1:
  • Power off the printer.
  • Disconnect the power cable
  • Wait for 30 minutes.
  • Connect the power cable
  • Power on
Solution 2:
  • Check the power supply
Solution 3: The voltage of the print head is abnormal.
  • Replace the Printhead
Solution 4: Check for the cable continuity between the carriage relay PCB and the main controller PCB
  • Replace the cable.
    Replace the carriage relay PCB.
  • Replace the main controller PCB
Oct 26, 2017 | Canon Office Equipment & Supplies
03130031-2F51
This is a printhead error
Remove the Printhead(s), clean the contacts,and replace in printer . Run nozzle check and try to print.
If you are able to print a few pages then get the same error, the Printhead will need to be replaced.
Good luck
Jul 10, 2014 | Canon imagePROGRAF iPF8000 Printer
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
http://mail.davin.be:8888/CANON/BOOK%20IPF/IPF750/ipf750_755-sm.pdf
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Canon IPF 710 with error code E161-403E, abnormally high printhead temperature how do I clear/remedy it?
The error apeared when i stated to print !
How to solve it.
It is about 6 month since we started to use your product.
Apr 22, 2010 | Canon imagePROGRAF iPF8000 Printer
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Error code 6500
That's a strange error for that machine, a network error? I would try removing the printhead and see if the error changes to printhead not installed, could just be a defective printhead which can cause strange errors.
Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
What is error code 3802
"Printhead Failure" (error code 3802)
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Remove and install the printhead two times.
  4. Wait 30 seconds to allow the printer to reset.
  5. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  6. Close the printer access door.
If error condition continues, contact Kodak for printhead replacement.
Best of Luck
Nov 17, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
IPF610 Canon "Print head needs cleaning"
I've had the same problem, and finally after hours of frustration, got Canon to provide a new PrintHead at no charge
Jun 02, 2009 | Canon imagePROGRAF iPF8000 Printer
Canon ipf 8000 Error Code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Feb 21, 2009 | Canon imagePROGRAF iPF8000 Printer
IPF8000 PLOTER
Jun 18, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon imagePROGRAF  iPF8000 Printer Logo
13,537 people viewed this question
old marine
old marine
