Philips DIRECTV H20 DTV Receiver
Problem for Philips DIRECTV H20 DTV Receiver
Direct tv came with apartment. has never worked
By smokeyntiger on Nov 04, 2009
direct tv came with apartment. has never worked says NO Signal on the screen I had cable put in but why pay for somethiing that is already included? I have tried everything but since it is not in my name the direct tv wont answer my ???? There are 2 cables in here and I have tried them both. The time warner cable guy hooked one right up no problem and disregarded the other cable even though it is closer to the tv....please help thanks....( i have followed the cable to the dish and it appears to be connected and the owner did get an entirely new box for me but it is the same as the old one) .
Solution #1
posted on Nov 04, 2009
Not Rated)
Zim_256
Rank: Guru
Rating: 86%, 273 votes
Try calibrating the antenna to the nearest satellite. The DirecTV box has in the installation menu instructions on how to do this. You'll need some tools like a socket wrench to unlock and adjust the antenna. Put in the menu your global position or your city and select the transponder that gives better signal. If all satellites are out of signal, move the dish until you receive at least one.
To calibrate the dish from the ceiling or wherever it's installed, put the TV volume up until you hear the short "BOOP" sound from the dish location. When you get signal, the "BOOP" will turn to a continuous "beep" with a higher pitch when higher the signal you're receiving. After getting the best signal, switch transponders to see if there's another with better signal, after that, lock the antenna and try watching a channel.
Was this helpful?
Yes
No
Popular Solutions for Philips DIRECTV H20 DTV
Questions and Unsolved Problems for Philips DIRECTV H20 DTV
Do you recommend Philips DIRECTV H20 DTV Receiver?
Answer
Answer
Hi, Im having trouble with satellite signal from tuner 1, I have alot of 0's or low readings when I... (More)
Answer
my direct tv has no signal strength and is set to the right settings when i enter my zip, now what... (More)
Answer
Can't program remote for Sony Blu-Ray DVD ModelBDP-S560. Codes in manual, including 21033 do not... (More)
Answer
I have a DirecTV H20 Receiver/dvr. When I program it to record a HD program my receiver immediately... (More)
Answer
my parents set a parental control and set it to only PG.Also we have tvo (record shows) and i dont... (More)
Describe your TV Receivers and DVRs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Receiver and... Experts
Top Audio & Video Equipment Repairmen
in , AK
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
