That sounds like a cpu, ram or motherboard issue. The cpu could be bad or unseated, the ram could be bad or unseated and it could be anything on the board.
Gnerally the common thing that will cause it not to boot and not show any error or video etc will be ram. That is where I would start. You can try removing any modules or just trying one at a time or in a differant slot. Ram is cheap(ish) right now so it would be worth fixing if that is the cause. You can replace the cpu or swap it out. Replacing the motherboard requires it be stripped down and you may find a new motherboard for $150-$200 and then the labour on top. Better check for any warrenty if possible. And if you need to pay out of pocket consider getting a replacement laptop. New ones have dropped down enough that the repair cost could be as high as replacement.
On my Compac Presario R3000, the L.E.D.'s that indicate caps, wifi, touch pad, and number lock...
(More)
On my Compac Presario R3000, the L.E.D.'s that indicate caps, wifi, touch pad, and number lock either light dim or are out most of the time, if i tap lightly next to the touch pad they come on bright for a while, where can i get info on the power path for these lights, i know how to disassemble and solder etc. I am a tech who repairs small SMD circuits. I have looked internally for a broken connection and haven't found it. Thanks, Lee P.S. Ya, fixed the power jack a few times, crummy design!
sound coming from laptop speakers and headphone at same time on compaq presario v3000 with xp. cpu...
(More)
sound coming from laptop speakers and headphone at same time on compaq presario v3000 with xp. cpu was recently formatted and xp re-installed
On my Compaq presario R300 laptop the following keyboard malfunction is present.When this @ key is...
(More)
On my Compaq presario R300 laptop the following keyboard malfunction is present.When this @ key is used it shows as " Can you help?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
