my amana upright gets cool but not cold enough to freeze probably not even as cold as a fidge. the problem started when we moved and stored it out in a shop that was partially heated. since then we have moved it indoors still does not freeze
Good day, Somewhat handicapped not knowing if it's a conventional freezer or frost free. 1. If it's frost free check to see if the fan motor is running in the freezer compartment. 2. As well if it has a fan motor in the compressor compartment, see if it is running as well.
3. If it is a conventional model, make sure it is turned on and make sure it is running. If running, then it has lost it's refrigerant charge or the compressor has lost it's pumping capacity.
4. If it is item 3, then unless it's less then 5 years old, the sealed system/compressor problem is so pricey that it's not a practical repair. If under 5 years Amana will pay for these repairs, whether it's conventional or frost free.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
thank you for your time that atleast points me in some direction
" - vanglin
Popular Solutions for Amana 15.0 cu. ft. / 425 liter
Amana 15.0 cu. ft. / 425 liter Upright Freezer Deepfreeze...
My freezer is blowing up freezer bags like baloons. Not just any one kind. Even items bought and...
(More)
My freezer is blowing up freezer bags like baloons. Not just any one kind. Even items bought and frozen from store. Ice is building up at the bottom could this be causing the problem
I've just filled my Amana upright freezer with meat for the holidays....when I plugged it in all was...
(More)
I've just filled my Amana upright freezer with meat for the holidays....when I plugged it in all was fine. A day later the small outside light at the bottom of the freezer began to blink--what does this mean? Thank you
