Fuji Finepix A610 Digital Camera Logo
Posted on Nov 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dropped my camera and now it won't turn on.
Dropped my camera and why won't the power turn on?
ALBERT GARCIA
Level 3:
  • Master 975 Answers
  • Posted on Nov 04, 2009
ALBERT GARCIA
Master
Level 3:
Answers
975
Questions
5
Helped
358390
Points
2970
NEED to take to an AUTHORIZED CAMERA REPAIR SHOP ,theres nothing else you can do to fix it due to the delicate and sensitive parts , good luck , AJ
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
Kodak easyshare c1530 won't turn on after slighty dropped
Hello Doris, You can "GENTLY" try to push the lens slowly back into the camera with the palm of your hand, note I said gently and slowly, do not use force !!! Then turn on camera and see if this helped, if not it is repair time.
1helpful
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
3helpful
I dropped my Canon PowerShot SX120 IS Digital Camera and now there is no power. Is there a reset button on the inside or anywhere?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
1helpful
My samsung TL220 i dropped it won't power on or anything
Things to check first for a camera that won't turn on (no power, no lights, no noise, nothing) are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
But if there is some electrical activity, then you're more likely experiencing a lens error. In that case, see this article.
and this video:
Lumix tz8 won't turn on
Are you saying that there's no electrical power at all? Or do you mean that the camera won't complete its startup sequence, and gives you an error? I'll assume the second first, as that is more common:Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
But if you really meant that the camera is not showing any electrical power at all, then see this.
1helpful
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
