Whirlpool Elec Dryer timer didn't turn the dryer off at end of cycle. Nor would it heat when timer is set to heat position manually any where on the dial. Upon inspection, the heater coil is broken. Should the timer run with broken heating element? Is it a coincidence that the two failed at the same time?
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Comments:
Nov 04, 2009
- if you have heat try tapping the timer and see if it advances,could have a bad timer,tapping it sometimes will advance it past the sticking point but you still will have to change it out
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 7.0 cu. ft. HE4
Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric...
dryer won't heat up and when you push to start button it starts to run but as soon as you release...
(More)
dryer won't heat up and when you push to start button it starts to run but as soon as you release the button it turns off
Kenmore HE4 electric dryer- relocated it and now the controls dont work- light comes on- but thats...
(More)
Kenmore HE4 electric dryer- relocated it and now the controls dont work- light comes on- but thats all. Any ideas?? Thanks
The dryer seems to be taking much longer to dry all of a sudden (2-3 times longer than just...
(More)
The dryer seems to be taking much longer to dry all of a sudden (2-3 times longer than just yesterday). It is tumbling, blowing warm air out the vent and all the controls appear to be working. It seems more warm than hot even though the temperature setting is at high. Could the gas heating unit be on but not heating as optimally? Thanks! Kirk
