Question about Sony KP-EF41 41" Rear Projection Television
No picture at all!!! :(
Hi guys i have had this tv for about 6 years and its worked perfectly untill about 2 weeks ago.
Theres no picture at all, no menu comes up, but there is still audio. Whats the most common thing that could have happened?
do you recommend i open it up and check for loose connections, or should i just call a qualified technician to take a look, any ideas on the price for a fix?
  • ramis Jan 04, 2008
    Thanks for the reply.
    By tubes do you mean the 3 light globes?
    Genius:
  • 1,139 Answers
Hello ramis,
The symptoms you have described could indicate a problem with the HV section of the TV that supplies voltage to the CRTs (RGB Tubes) if this is the case I would suggest that you let a qualified TV technician work on the problem.
Posted on Jan 04, 2008
  • Henry McKelvey
    Henry McKelvey Jan 04, 2008
    Hello ramis,
    Yes they are Red Green Blue Cathode Ray Tubes, they are supplied High Voltage from a transformer located on one of the boards. I believe that this or its associated circuitry is the problem.
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
No video on my Protron PLTV 4250
check the video with a flashlight against the screen, if present the backlight inverter has failed.
Dec 07, 2008 | Protron PLTV-4250 42 in. LCD Television
Vizio 50'' Plasma AV1 & 2 Ports Unresponsive
Put off the TV Using the remote .Then unplug the TV 's power line from power source.Allow this for Just Over one minute .Then plug back the powerline and your TV should be okay.
i had the same problem with wii and this fixed it .
Nov 26, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Television picture issues...
I had the same problem when I accidently hit the remote. If you are hooked up to cable make sure INPUT is on the correct setting -- AV, S-Video, YPbPr1, YPbPr2, VGA, HDMI1, HDMI2, ATV & DTV (see button on TV or remote). Hope this solves your problem.
Jul 27, 2008 | Astar LTV-3201 32 in. LCD Television
Samsung LN-R328W TV Psychedelic picture
Multiple color lines around the image is most likely the convergence is off. from the menu find the option for convergence
follow the adjustment prompts. if that don't work the board has two IC's that are probably bad
May 02, 2008 | Televison & Video
Sony KP-EF41 41" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
