Question about Brother DCP-110C All-In-One InkJet Printer
Maintenance Mode Hi can you please help me. I have just changed the print head in my DCP-110CN. The instructions I have, which cover a number of printers, assume a telephone key Pad is present, but the 110 doesnt have one. Can you tell me the key sequence to get into maintenance mode to clear the error 44 and to enter the new print head ID number. Thanks Les
  • 832 Answers
Les,
you dont have to compute any numbers.
Simply change the printhead.
If you receive an error starting with 4 again, this means that the "new" ph is faulty, too.
Save lifetime and energy and buy a new dcp 130 or 135 because this is cheaper.
Posted on Jan 04, 2008
Unable to init see troubleshooting and routine maintenance chapter in user's guide. Please help me!!!
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.
Disconnect the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2. If the error continues to appear, move the print head and examine under the print head.
NOTE : The images shown below are from the representative product and may differ from your Brother machine.
2-1.Disconnect the Brother machine from the poweroutlet.
2-2.Open the scanner cover by pulling up on the lower right corner of the cover.
2-3.Check the print head's position.
In the example photo the print head is positioned at the left hand side of the platen area.
2-4.Gently move the print head to the center.
Examine under the print head. If anything is found, remove it.
Close the cover and reconnect the machine to the power outlet.
Feb 20, 2014 | Brother DCP 115C All-In-One InkJet Printer
Manually clean print head dcp-j725dw
Explore the options on the printer display. Find maintenance and poceed from there. You will have to use menus anyway (on the computer or on the MFC display).
Nov 20, 2013 | Brother DCP-J725DW Inkjet Multifunction...
How to fix the DCP-6690CW unable to clean 46 error
Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
Jul 29, 2013 | Brother Ink for Dcp-6690cw and Lc-1100
Brother DCP 195c print problam [black and yellow] punjabi
try to clean the print head 2-3 times,if the problem persist chage the print head
Feb 24, 2011 | Brother DCP 165C Compact Color Inkjet...
I'd tried to fix my brother dcp-120c printer, it was unable to print. i followed the instruction of troubleshooting manual but i cant fixed it. the flash display on my LCD is MACHINE 5A. What will i do?
The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip behind the printer head.
Also, try a reset:
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 15, 2011 | Computers & Internet
I cannot print from printer brother DCP-135C with an error message - Clean Unable 46, please assist
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
Jan 28, 2011 | Brother DCP-135C Flatbed Digital MFC...
Clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
Apr 09, 2010 | Brother DCP 165C Compact Color Inkjet...
I have a machine error 36 of brother dcp-115c help me
Machine error 36
**Head/carriage unit travel error***
Try to find any obstacles on the travel path of the head/carriage unit. If you cannot find, next steps are:
- Replace the carriage PCB.
- Replace the head/carriage unit.
- Replace the CR encoder strip.
- Replace the carriage motor.
- Replace the main PCB.
- Replace the power supply PCB.
- Replace the maintenance unit.
Nov 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
DCP 117C Brother ink jet printer: Although ink cartridge is filled, is showing black nearly empty error message. No black is getting through on test printing after head cleaning procedure.
two diffrent errors:
1. near empty. I guess your cart is at full level.: Take cart out. unplug dcp from power. leave scanner open. replug to power. machine will come up and demanding cart. insert cart. close cover. answer display if its changed!
2. press menu then start bk-copy then four times arrow up. machine will be in maintenance mode. press by help of arrow-up and set: 7 (set) 6 (set) 3 (set) start bk-copy. machine will do a power purge cleaning. when finished press 9 (set) 9 to leave maintenance mode. run a test print and set date/time again!
Apr 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Error 5A
The purge cam has stopped abnormally.
The unit might be defective or the encoder disc which is mounted on one of the three big gear wheels is stained
or broken.
I guess the purge cam shaft is broken (this is the noise you can hear)
Anyway you have to change the whole print unit.
The spare part costs are more then a new dcp 130c 0r 135c!
Even if you try to change the parts with another dcp 110c its not worth the costs and energy because of other probs that might happend...
Jan 04, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
324 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
