Question about Zanussi FJS1225W Front Load Washer
Zanussi washer just cleaned and unstuck pump put back together but now the pause button is flashing and machine will not start
    President:
  • 1,294 Answers
Press "end of cycle" button to clear.........................
Posted on Jan 04, 2008
I have a zanussi zj1217, when select any programme it sounds as it is about to start, but before any water even goes in the start/pause button starts flashing. Any idea's.
check pump /pump filter electronics can sense if the pump not working at the begining of the programme try a pump only prog.Can be heater or main motor with an earth fault. you need an insulation tester to isolate the fault.
Jul 25, 2010 | Zanussi ZJ1217 Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
I have an e50 fault flashing on the display
Hello, E50 is relating to the main motor,it could be the brushes,tacho or something more serious.,try checking the brushes first follow these instructions.
Hold the start/pause and skip/reset together then press the on/off button keeping the other 2 buttons held until you get chasing lights,now release the first 2 buttons.Now press the fabrics button until the light goes down t60 degrees or the pump cuts in.Then take it on I think step by step until an error code displays make a note, to cancel hold the 2 buttons start/pause and skip/reset and the error code should go but if it reappears then the fault is still there.
Thanks
Jun 14, 2010 | Zanussi ZWF1430W Front Load Washer
Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Zanussi IZ12 Pumps, then Pause LED is flashing.
Remove the power cable for few hours and then try again. Good luck!
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
156 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
