We found that the machine was not spining clothes dry so I changed the motor brushes, however this may not have been the problem as we find that mid cycle the pre-wash light starts flashing and the program stops. it will spin if you put it on the spin program. Can you help?
Erratic behaviour in wash programmes can often be due to clogging of the path between the tub and the pressure sensor which senses the water level in the tub. Clogging can result in water level being incorrectly detected (may read as too high or too low) for the stage of programme that is executing, which can result in a halt of the programme.
Rating Locked! (?) Nevilleish has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on not fnishing wash cycle!:
