Home | Reddy | Heater-30-55,000 BTU Variable | I have a reddy hea...
Reddy Heater-30-55,000 BTU Variable
Problem for Reddy Heater-30-55,000 BTU Variable
I have a reddy heater model blp55va and when I
By thamer07 on Nov 04, 2009
I have a reddy heater model blp55va and when I start it by pushing red botton it starts but when i let off botton the flame goes out.
Solution #1
posted on Nov 04, 2009
Not Rated)
tbugger
Rank: Guru
Rating: 90%, 68 votes
Test the thermocoupler:
Normal 0 Heater will run as long as the control valve is pressed.
According to DESA test these parts. NOTE: Not all heaters are equipped with
A relay.
Thermocouple
Turn off gas supply. Remove thermocouple
from gas valve. Using a digital
multi-meter set to the lowest DC millivolt
setting (meter needs to have alligator clips
on ends of leads), clip black lead to the
very tip of thermocouple (end removed
from valve). Clip red lead to the outer casing
of thermocouple for ground. Relight
unit output should be between 18 and 28
millivolts.
Relay
Turn off gas supply. Remove bottom of
base (if equipped). Relay is a normally
open circuit between terminals 4 and 6
which closes when current is supplied.
Using a digital multi-meter measure the
resistance. With no power to unit, resistance
between terminals 4 and 6 is open
circuit or no resistance. Apply power to
relay. Resistance between terminals 4 and
6 should be less than 100 mili ohms.
Was this helpful?
Yes
No
Popular Solutions for Reddy Heater-30-55,000 BTU
Questions and Unsolved Problems for Reddy Heater-30-55,000 BTU
Do you recommend Reddy Heater-30-55,000 BTU Variable?
Answer
Answer
The heater starts fine, but the gas flow is significantly reduced after a few seconds. Tried a... (More)
Answer
Tries to fire but shuts down after a few seconds. I have already ran it a few times this week. Now... (More)
Answer
Turns on with flame and fan and after 5-10 seconds shuts off. When I plug it in again, the same... (More)
Answer
my heater will fire up and run then if i unplug it and plug it back in the motor spins slow and the... (More)
Answer
55000 btu kerosene heater I ran great until i moved the heater to another room, plugged it back in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Reddy Heater-30-55,000 BTU...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
