Question about Motorola Mobility SLVR L7 Cellular Phone
Screen broken My screen is broken and i was wondering if you could tell me the exact key stroke pattern to copy all the phone book numbers from the phone to the sim card??? can you help??
  • 38 Answers
From main screen:
Either 'a':
Press 'down' on your directional pad to open up the phonebook (default setting)
OR
Press the menu key and scroll down to the phonebook entry (I'm not sure if you remember where yours is, as I changed my menu around. My phonebook listing is the first one. Dunno if this helps at all)
Then, once you are viewing your contacts:
Press the menu key.
Press 'down' on the directional pad eleven (11) times to highlight 'copy'.
Press the center of the directional pad in to select the highlighted menu item.
Press down on the directional pad once to highlight the 'all to SIM' option.
Press the center of the directional pad in to select the highlighted menu item (MERGE)
OR
Press down on the directional pad once to highlight the 'OVERWRITE' option, and then press the center of the directional pad in to select the highlighted menu item.
Depending on how many contacts you have, this will take about 30 seconds per 100 contacts.
Posted on Jan 07, 2008
My nokia 2730 screen is broken and have put sim card in another phone but no contacts.How do i copy numbers to sim on broken screen when i cant see menu? Neil
Not a problem friend. Just be patience. 1. Just press you end button(i.e your red button) 2. to check weather key pad unlock or not for that just dial any number and press call button, if success then press red button. 3. press menu button, and take the help of your manual book which comes with your phone. 4. see where exact the contact option is and go to that using your navigation key and press ok button (it all will be in imagination as your screen not showing any things)
5. using your navigation key come down to option copy contact, and do the same as manual book show hope it will work for you. As it a hectic job but sure it will help you out.
Thanks
Apr 16, 2011 | Nokia 2730 Cell Phone
Broken LCD screen
menu > key 7 > key 4 > key 3 > ok Blue tooth active
Jul 14, 2010 | Samsung S3500 Cell Phone
I need the exact key stokes to copy my contact to
why not connect that to your pc and you can copy the sim contacts there
Feb 16, 2010 | Nokia 6610
Display ripped off phone, Copy Numbers to Sim card?
Red key (to make sure you're on the home screen)
Left key (menu)
3 (Address book)
5 (Copy All Contacts)
2 (Handset to SmartChip)
1 to Keep original, 2 to Delete original (I'd keep it, just in case this doesn't work)
(Beep)
1 (Yes to confirmation)
Wait for another beep
Done.
Oct 25, 2009 | AT&T LG CU515 Cell Phone - Black
Need keystrokes to save address book to sim
from main screen: MENU (top-left key), 8 (address book), 5 (copy all contacts), 2 (handset to smartchip), 1 (keep original) or 2 (delete original), and that's it!
Jan 18, 2009 | LG CG180 Cellular Phone
My sony ericsson has no screen
Ok, I figured it out. To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Jan 04, 2009 | Sony Ericsson K800i Cellular Phone
Front and inside screen stopped working
have the lcd replaced on the phone.
Jun 28, 2008 | Motorola Mobility V551
Screen broken
no reconoce mi equipo
Mar 25, 2008 | Motorola Mobility V300
Sony Ericsson Z525A-COPY PHONE NUMBERS TO SIM CARD -BLANK SCREEN
to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable2.gif for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
Dec 26, 2007 | Sony Ericsson Z525a Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
117 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
