Question about HP iPAQ H4355 Pocket PC
Now HP4355 won't work
Was working perfectly, unfortunately wanted to save battery (i.e. was at 60%), so rather than leaving HP4355 ON i was turning OFF, then ON (to get more info), then OFF (to save battery), then ON, then OFF, then STOPPED working. battery is at 60%+ (voltmeter output is 3.06V). when connected to power - charge light does NOT blink. is there a 2nd battery? could the ON-OFF switch be the problem?
MY HP OFFICEJET 4355 ALL IN ONE NOT WORKING FAX,SCAN,COPIER,WORKING ONLY PRINTER.
Posted on Oct 08, 2008
I was trying to put the color bottom ,won t change the color
unfortunately the coby company has gone out of business probably because they have produced an inferior product that has had many problems, many people are posting problems with these sets. it is better you just purchase a different brand of tv and leave this heartache causing product behind.
Apr 26, 2014 | Coby TFTV3227 32 in. LCD TV
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Dec 07, 2012 | 1992 Toyota 4Runner
Casio Classpad 330 batteries run out very easily.
This may or may not solve your problem but it might alleviate it. The calculator has a power saving mode which you can configure as follows.
Turn ClassPad ON
Tap the Menu icon at the bottom of the screen.
Scroll down until you see the System Icon
Tap the system icon. After a few moments the calculator comes back and displays the system configuration screen.
At the top of the system configuration screen tap the battery icon (look for a + - sign).
This opens the power saving properties.
The power Save Mode will turn power saving mode automatically, after a day, one week or one month. It can also turn the power Save Mode OFF.
The other configurable setting is the auto Power OFF. It turns the calculator OFF after 1 min, 3 min, 6 min or 60 minutes.
Note: another possibility is the use of rechargeable NiMH batteries. Be aware that some manufacturers discourage strongly the use of rechargeable batteries.
Hope it helps
Apr 25, 2012 | Casio ClassPad 300 Calculator
Motherboard won't boot up cpu fan comes on hdd
Just after that there was NO correct answer to fix this problem causes the problem not solved even if it is marked as solved. Me too I have this problem, I was fix it by setting jumpers to default 60 Hz AC power because I won`t have 50Hz AC power or some AC power converter before PSU, I mean this is voltage errors, it`s need to be set to default +5V(60Hz) PSU not +5VSB(50Hz) PSU, (Step1) like might be set to USBPW12 to pin 3 both USB to right side inserted jumper it`s in left side of, near ATX 12v advanced CPU power cable connection socket. Next (step 2) is set up front USB jumpers to +5V or system won`t start up, it`s on motherboard about between PCI1 and PCI2 on right side it must be set to USBPW56 and don`t set it to USBPW78(5+VBS) because system won`t start up, the jumper must be set to right side I mean it`s last jumpers to right side need to be set up, because it`s +5V(60Hz) PSU supply. The USB wake-up feature requires a power supply that can provide at least 500mA on the +5VSB lead when these jumpers are set to +5VSB otherwise the system won`t power up. Next step if it still not starts up its BIOS fault, it`s easy to repair, just (Step3) turn off PC remove BIOS battery (it`s down to IDE cables), start it up wait a bit, then turn it off and turn it again on wait a bit again, turn it off place BIOS battery in to socket to be able save BIOS settings i mean battery is need to save them otherwise settings won`t be saved and Chassis will be broken. (Step 4) Turn PC on press del key after BIOS is load in open Power\Hardware monitoring\Chassis Intruder set to Disable, save settings exit. (Step5) If BIOS (PC won`t power up) it`s Chassis1 jumper fault, it`s need set to Default (Chassis signal, and GND(Ground)), it`s between SATA 2 and SATA1(Serial ATA connectors 7-pin it`s near and down to BIOS battery, the jumpers might be set to right side, after it`s completed repeat Step3 and Step4. CMOS is BIOS battery. If that all doesn't works Take BIOS clearing jumper in it`s clear state, near BIOS chip. Turn on PC with CMOS clear jumper turned on its work. Take beck jumper in its default state after that take bios chip out and CMOS battery out both them an two times restart PC after insert all beck if PC will be working all keyboard flashes once, after its in AC power.
May 07, 2010 | ASUS P4P800-VM Motherboard
The screen on my pantech matrix is reversed to the point where if i put it up to a mirror it looks perfect i didnt drop it or anything
Try taking the battery out, putting it back in and turning it on. Then about halfway through the load bar pull the battery out again. Do this twice, then leave the battery out for a couple days. If this doesn't work try navigating to SETTINGS in your phone and there should be an option to RESTORE FACTORY DEFAULT. Just remember to save all your contacts somehow.
Feb 24, 2010 | Cell Phones
Kirby 64 won't hold a save file
The battery inside the game pak has died, thus, it can no longer hold a save.
Buy a special screwdriver for n64 Game Paks. Unscrew the casing, then find the battery inside the Pak. Take it (the battery) to any store that sells watches, then ask for a replacement for that battery. Plug the batery (+ side facing you) in the Pak, then screw it back together.
Your game should now save. :)
Nov 22, 2008 | Nintendo 64 Console
Uae customer
even if there is power difference, all you have to do is buy a transformer that would convert 110 volts to 220 volts or vice versa. another issue that to be consider is frequency.
if the unit is designed to run at 60 Hz, then it would be slower when plugged to a 50 Hz supply. and the reverse, it would be faster if it is designed to 50 Hz and plugged to a 60 Hz supply.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Washing Machines
Security light on and car not starting
Put the key in ignition and leave in the on position for 20 minutes and it should start after that. I had the same problem with a 99 chev silverado an it worked for that. Hope it get you going. Thanks.Bear001
Jun 16, 2008 | 1998 Chevrolet Lumina
HP iPAQ H4355 Pocket PC Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
