There could be several reasons for washer not to fill .Fill washer with water and wait for the timer to get to the drain mode.Unplug the washer from the electric outlet.Open the case, and disconnect the water hose from the outlet of the water pump.If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.Reassemble hose from step 3.Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Thanks for contacting Fixya.com
Was this helpful?
Yes
No
Popular Solutions for GE WBSR3140DW Top Load Washer
during spin cycle the motor does not click on and the tub does not spin. is there a relay that might...
(More)
during spin cycle the motor does not click on and the tub does not spin. is there a relay that might have gone bad
The washer will agitate but won't rinse, or drain. It just makes a humming sound when it reaches...
(More)
The washer will agitate but won't rinse, or drain. It just makes a humming sound when it reaches that point of the cycle
The LED beneath the drum is blinking 7 times... I do not know what code this is. I recently had the...
(More)
The LED beneath the drum is blinking 7 times... I do not know what code this is. I recently had the motor replaced under warranty it worked fine for a few weeks then stopped again. Now the code it appearing and I do not know what the code is.
one of the 4 suspension rod came loose in my ge adora washing machine . Machine is off balance now....
(More)
one of the 4 suspension rod came loose in my ge adora washing machine . Machine is off balance now. wants to take of the front panel and balance the machine
