Tomtom GO 700 GPS Receiver
Tom tom go 720
shared by 14 users
posted by JRB1955 on Jan 04, 2008
When switched on i get red flashing circle with white cross and nothing else,i have tried tom tom home and and get a message that my device needs to download a file, but when i attempt to download i am told the file is not avaliable at the moment.
The device is about 3 months old and was working fine up until now,it was switched off for about a week during xmas and the problem has started since then.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
13 Other Users Have The Same Problem
Posted by Miramontes2 on Oct 22, 2008
I tried to download an update for the first time...and now it doesn't work. Theres a pic of my tomtom on the screen with a red circle with a white x. SO mad!
Posted by laladanny53 on Sep 03, 2008
when i turn on the gps show tom tom imegene with a cross
then not hapen nathing else
Posted by nyg8torfan on Jun 19, 2008
Got new TT Go 720 for Father's Day Sunday worked fine out of the box, connected to computer for updates, got red x, shut off tried reset, no luck, talked with customer support, no help, made it worse. 2nd Cust Supp person gave me a website, confusing to navigate and not all of the options mentioned were there, next person helped more but unit needed to be returned to store. less than 48 hrs later, same problems with 2nd unit, had computer wxpert check my system for problems nothing found, only suggestion - the bus terminal is a powered port, try plugging directly into front/back of computer, helped alittle, also tried plugging into car port, when unit couldn't be turned back on and this worked, unfortunately the program they recommended that I remove kept me from doing anything furthur, just as well because it wouldn't turn on without outside power any way, I contacted cust service again, 1st person suggested that I had charged it for too long...not possible with Li ion batteries, Also suggested that I not update it until I used it for a month or so, ridiculous how else do I charge it without buying a seperate charger, or leaving it in my hot vehicle which is clearly marked not to do on the box.Next person at cust service on with me for 2 hrs very nice but nothing worked, sent me "upstairs" to another department, same "****" all over again, no help. I sent them a very long e-mail about their quality control issues.... against my better judgement I just got a 3rd unit today, I have no intention of updating anything until I know its going to work this time. If I have another problem I am going to change to a
garmin, I chose this one due to the features that I wanted and ease of use, I have a Garmin hand held that I've had for 6 yrs, and had no problems right out of the box or since, however it is not practical when driving, it is meant more for trekking/hunting etc...I'll keep youall informed......
Posted by Guest on Mar 09, 2008
I have deleted root files from my tomtom 720 and i don't have any back up. whare can I get them from?
Posted by Plane-nuts on Feb 28, 2008
It worked yesterday and now I get the big red "X" flashing.
What happened?
Best Solution
posted on Jan 27, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks,
Worked on my TomTom 520, I also saved the files which I deleted from the TOMTOM and then put back the files which where not reinstalled, via the web.
thanks to hanwayg
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Tom tom go 720:
I don't want to Accept this solution
Best Solution
posted on Apr 18, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
Thanks !
Worked for me as well!
Connected TomTom720 out of the box, installed TomTom HOME which instructed me to upgrade but I'm pretty convinced it did not first suggest to make a back-up. After the upgrade I got the white cross.
I was still able to create a back-up, both from TomTom Home and manual. I then followed the instructions (deleting the root files), started TomTom Home and followed the upgrade instructions after which everything worked as it should be!
Thanks again, there is nothing more frustrating then having I new toy which does not want to play!
Thank You!
Best Solution
posted on Jan 13, 2008
FixYa! (100)
hanwayg
Rating: 100%, 2 votes
I have exactly the same problem. Everything worked fine until I did a software upgrade. I have tried the reset suggestion but it has not fixed the problem. I have been told that a possible solution is to install the version of the OS that was there prior to the upgrade but I cannot find this anywhere
Comment posted on Jan 14, 2008
This worked for me
• The device hangs in the start screen (splash screen)
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home from http://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
Rating Locked! (?) JRB1955 has rated this solution as FixYa!
Thank You!
Best Solution
posted on Sep 03, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
This fix worked fine on my 520.
THANK YOU, THANK YOU, THANK YOU!
Thank You!
Best Solution
posted on Jun 12, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
THANK YOU FOR THE FIX!
Thank God...I had borrowed this from someone and I thought I had messed it up for good.
Thank You!
Best Solution
posted on Jan 19, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
Thank you - that worked for me! - TomTom720 with identical problem. TomTomHome was failing to make backups (I did not have enough space on one drive - would have been nice to have had a warning though), but done a manual backup. Once again, thank you for sharing!
Thank You!
Best Solution
posted on May 18, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
Thanks a million. It really works. Good job:))
Thank You!
Solution #8
posted on Sep 15, 2008
Not Rated (0)
kmwhit
Rating: 0%, 0 votes
Thank U!! You are a lifesaver! I updated my BF tomtom and ruined it...with him needing it for work in the morning. And hour later with your solution and it's fixed! Thank you so much....:)
Thank You!
Can you Help with these GPS Devices problems?
Where can I download maps for the Sansui GPS??
battery om my tomtom 710 shows redish color & sometime...
can i hit reset
Last time I updated my Tom 710, but since then I am...
Device keeps on rejecting sd card - despite restart and...
13 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 22, 2008
same
Comment by Guest, posted on Feb 21, 2008
I was down loading new option & then a update I dont know what went wrong went I turn it on I get a big flashing red X
Comment by Guest, posted on Feb 11, 2008
same exact thing after the update download, do not dowload the updates at all cost, unless you wanna render your gps useless
Comment by Guest, posted on Feb 10, 2008
have same problem following upgrade...I am lost
Comment by Nass, posted on Jan 20, 2008
I have exactly the same problem I have just buy it today please advise the red circle with the X sign and file not available
Comment by hanwayg, posted on Jan 13, 2008
I have the same problem with a GO 720. Everything was fine until I did a software upgrade. I have tried the reset suggestion but it makes no difference. I have been told that a possible solution is to reinstall the original OS (i.e. the one that was there before the upgrade) but I cannot find this anywhere
Comment by whitewolf, posted on Jan 08, 2008
my tom tom go 720 worked fine until i upgraded it now all i get is the red dot with a white cross on it.
Comment by Guest, posted on Jan 05, 2008
Updated to the lastest v7.221 and now the Tom Tom starts up and then stops at a red flashing cross.
Loading problems.
Repair Service
Find GPS Device Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
