Problem for Digital Cameras
Generic problem for all Digital Cameras
Sony cybershot dsc-w55 lens will not com...
sony cybershot dsc-w55 lens will not completely retract at power down and when started up you get ''Access........turn power off an on again'' lens doesn't move
Best Solution
posted on Nov 04, 2009
Rank: Guru
Expert
Rating: 92%, 210 votes
Hello
This either means that something is jamming the lens , or that the lens sensor is faulty. This is a very , if not the most common problem with modern digital camera's.
Most of the time the problem is that sand , dirt and grit gets lodged in the camera lens barrel thus keeping it from extending properly but could also be caused by a drop or a hard knock on the camera.
Firstly , the odds are not with you on a DIY fix so don't be disappointed when the following steps do not work.Nevertheless , some people have fixed their camera's using the following steps.
Use these at own risk as it may further damage the camera.
Firstly try charging your batteries overnight and then try the camera again tomorrow.
Try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
These 3 options provide your camera with more power available to the extension mechanism which could overcome some of the particles that are lodged in there if there are any.
Try using compressed air (best is a clean air can bought at a electronics store) and blow between the lens and the casing. This should help dislodge some of the particles.
Look at the lens , and if some of the lens 'circles' are misaligned or not concentric then try wiggling it (while holding camera lens down) so that some of the particles can escape. Also try moving the lens away from the side with the biggest gap (also upside down)
Try gently pushing or pulling the lens when it tries to extend but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
As a last resort if you decide to replace the camera try hitting the camera near the lens with increasing force with the palm of your hand. Between each hit , try using it again.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise works. Good luck and don't hesitate to contact me if you need further assistance or information.
Regards
Stephan
Was this helpful?2 people thought this was helpful
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Sony cyber-shot dsc wx1 digital camera
I am thinking about buying a Nikon L100 camera. I would like to know what others think about the...
(More)
I am thinking about buying a Nikon L100 camera. I would like to know what others think about the camera.
Do you have software I can download. Lost my CD.
i have poblem that my camera show me message change the batteries again &again even...
(More)
i have poblem that my camera show me message change the batteries again &again even batteries are new
my digilife ddv-S670 is displaying ''card locked'' even if the SD card is not locked
