Question about Polyview V17E 17" LCD Flat Panel Monitor
Horizontal Position Unstable
Running monitor at native resolution, and sometimes it would switch on shifted to left, and other times shifted to right 10 pixels or so.
I pressed "auto" to centre it each time it was out.
Came back from holidays and now it is left 20 pixels and will not "auto" correct any more. I can manually adjust it back.
What is the cause of the "amnesia" regarding my settings, and why won't the auto correct work anymore?
  • 37 Answers
Sounds like a electrolytic capacitor has aged/failed in the positioning circuitry. The failure could also be internal to a micro circuit chip. With out skematics and signal tracing I can't say what the problem is. It is possible, however unlikely, someone has spilled a liguid into the adjustment controls and the position switch is shorted causing a constant signal to move the screen.
Good luck
Posted on Aug 26, 2008
Projector Image Cut Off, Native Resolution Not Recognized by PC
after you connect the laptop and the image shifts to the right, press auto adjust on the remote and the image will get OK.
If not try resetting the projector settings to factory [not the lamp settings]
this should solve the problem
if not change the main board
Jan 15, 2013 | Panasonic PT-AE900U Multimedia Projector
DISPLAYING ON SCREEN THAT VIDEO INPUT OUT OF RANGE
Right click on the back ground of the computer desktop. If windows XP click properties, if vista click personalise. Now look for settings and move the resolution slider to 1024 X 768. This is the native resolution for this monitor.
If you still have the HZ error, click on advance look for the monitor tab, and make sure it is set to 60Hz
Mar 02, 2012 | NEC MultiSync LCD1525V (White) 15.1" LCD...
How do i get my computer out of the resolution mode?
Apparently the monitor screen resolution setting is not correct. Screen resolution stays up until it is corrected.
Either the setting is off in Windows, or you have been changing the monitor settings, with the monitor.
WinXP:
Right-click on an empty area of your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on the Settings tab.
Go down to where it states Screen Resolution.
What is the pixel setting? For example mine states 1600 x 900 pixels.
I am running dual monitors, and this is the correct screen resolution for the Primary monitor.
If it wasn't I would Left-click on the Slider, hold the left mouse button down, and slide the Slider to the correct native resolution.
(Under Screen Resolution is a line. To the left it states - Less
To the right of the line it states - More
The Slider is the rectangular down arrow on the line )
ALSO;
Under the Color quality heading, make sure in the box under it, that it states - Highest (32 bit)
IF not, left-click on the blue down arrow to the right.
Then left-click right on - Highest (32 bit)
How to know what is the native resolution for your monitor?
Look at the manufacturer name, and the model number on the back.
Type this information in your browser search bar, then click on the search icon.
Look for Specifications.
If you changed the screen resolution settings with the monitor, press the Menu button. The screen should go off.
ALSO, with a new monitor there is an Installation CD Disk, provided with it.
This disk MUST be used. It has the drivers for the monitor on it.
[ Drivers: Small pieces of software that allow the Operating System to 'communicate' with a device.
The monitor is a Device.
Windows XP, and Windows 7 are two examples of an O/S.
Operating System ]
If you have Vista or Windows 7, post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 11, 2012 | Dell Computers & Internet
I have a 20 inch monitor that the screen is off center.The picture is blank 2 inches on the right and part of the left is missing.
I am guess your have a CRT monitor. There should be a menu button or knob on the monitor. Press it and a menu should come up that will allow you to adjust the position and size of the screen display.
If you have an LCD monitor, the resolution of your desktop is smaller than the screens native resolution. There sould be a button marked "auto" press it and it should correct it. If not, find the desktop screen resolution section in your operating system (control panel) and make sure it is set correctly. If it is wide screen, set it to 16:9 and then set it to whatever has the word "Native resolution" written beside it.
May 14, 2011 | Soyo Computers & Internet
I am trying to hook up my monitor to my new PC
connect the monitor cable to the back of the pc, then plug the monitor to power supply and switch on the pc
Jan 23, 2010 | Computers & Internet
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Start up screens are off to the left.
There's nothing wrong with the monitor. Monitors remember the settings for different video modes, including horizontal position. The video mode used when the splash screen displays is a size almost every monitor can handle. Then the mode switches to whatever you've set once Windows finishes startup. As long as the display is normal once Windows is running, you really don't need to be concerned.
If you want to correct the problem, you need to put the monitor into the same resolution and use its menu functions to adjust the size and position. Try pressing F8 when the machine boots to get into the Windows startup menu. This will probably also be shifted, so you can adjust the settings while the menu is being displayed.
Apr 16, 2009 | Computers & Internet
Horizontal view on screen will not re-center
You want to locate Position or Horiz Position from the Menu screen. Press menu first then Up or Down to select the item you want then Left or Right, I can't be more specific as all monitors are different - but there isn't a single button to center. You could also try the different input settings (Analog, Digital, etc) if the Autoselect isn't working properly.
Dec 12, 2008 | Computers & Internet
Image/screen shifting with mouse position
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Feb 21, 2008 | Apple Cinema Display 23" HD Monitor
Polyview V17E 17" LCD Flat Panel Monitor Logo
71 people viewed this question
Top Polyview Computers & Internet Experts
David Payne
David Payne
Are you a Polyview Computer and Internet Expert? Answer questions, earn points and help others
