Maytag Atlantis MAV6000 Top Load Washer
Problem for Maytag Atlantis MAV6000 Top Load Washer
It wont cycle thru anything
By kristy_barne on Nov 04, 2009
it wont cycle thru anything
Solution #1
posted on Nov 04, 2009
Not Rated)
e-Guru
Rank: Wiz  Washers & Dryers  Expert
Rating: 84%, 279 votes
There could be several reasons for washer not to fill .Fill washer with water and wait for the timer to get to the drain mode.Unplug the washer from the electric outlet.Open the case, and disconnect the water hose from the outlet of the water pump.If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.Reassemble hose from step 3.Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Thanks for contacting Fixya.com
Was this helpful?
Yes
No
Popular Solutions for Maytag Atlantis MAV6000 Top
Questions and Unsolved Problems for Maytag Atlantis MAV6000 Top
Do you recommend Maytag Atlantis MAV6000 Top Load Washer?
Answer
Answer
The washer fills with water and stops when at the correct fill level, but doesn't start agitating or... (More)
Answer
I think filters need cleaning as clothes covered in lindt and clothes not being washed properly.... (More)
Answer
My MayTag Atlantis Washer is not dispensing fabric softener during rinse cycle. Soap is not... (More)
Answer
maytag washer atlantis not working, not spining, power trips, and smells like burning rubber.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
