This is a Long Drain Error. If the drain time exceeds eight minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the display.
There might be many reasons :-
1. Check the drain hose and make sure it is not clogged or kinked. 2. Make sure all the electrical connections at pump are secure and fine.Pump should be running. 3.Check the drain pump filter .It should be cleaned.
during washing it stops and sd appears on the estimated time left, then it starts again and then at...
(More)
during washing it stops and sd appears on the estimated time left, then it starts again and then at the end says sd again, till I take the clothes out
LP Front Load Washing Machine leaking a lot of water during use from the lower part of machine. It...
(More)
LP Front Load Washing Machine leaking a lot of water during use from the lower part of machine. It will leak soapy water and clean water. What could it be?
