Question about HP OfficeJet G85 All-In-One InkJet Printer
Power-on "initializing" power-off, repeat same cycle(process)
As above mentioned;
At first 18 V DC power supply then indicate "Initializing" on the display window then power off, after 5 sec. indicate "Initializing", power off.....
repeat same process as above.
  • swyche007 Jan 07, 2008
    When I power my g85 up I get the following error ba000004 with lights blinking telling to turn it off and then back on. I keep turning it off but the problem is still there. Can some one help?
  • pae61 Jan 05, 2009
    i have the same issue with my g85 driving me mad!!!
    President:
  • 4,402 Answers
The all-in-one product display always reads "Initializing" This may occur in a low power situation. Follow these steps in order to determine the cause:
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  3. If the all-in-one has an ADF with an external cable plugging into the back of the product:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable, and turn on the power.
      • If no change, the problem is not the ADF.
      • If the problem clears, turn off the all-in-one, unplug the power cable, and plug in the ADF.
      • If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  4. Unplug the USB or parallel communication cable from the back of the all-in-one and try to power up the all-in-one. The computer may be grounding out through the communications cable. If this corrects the issue, check the grounding of the computer and outlet. If the above steps did not resolve your issue, contact HP for additional issue verification or the servicing of your product.
Posted on Jan 15, 2008
Screen says initializing
You may have a faulty battery/phone. This seems to be a common problem with this type of phone. If you can take it and have them check it for SAFETY CONCERNS That would be ideal, as they can reset it for you.
Caution! This WILL erase everything on the phone. You will have to confirm you want to do this before it will complete. (This is why you backup your phone. You may wish to remove the SD card FIRST.)
1. Ensure the device is powered off.
2. Press and hold the Power button for 3 seconds then release.
3. With the LED illuminated red, press and hold the Power button+Volume down key+Camera key simultaneuously then release.
The LED illuminates approximately 20-30 seconds after releasing the power button (step 2). The 3-key combination must be pressed within the 1-2 second timeframe that the LED is illuminated.
4. Press the Power button to confirm and continue.
5. Again, press the Power button to confirm and continue.
( Allow several minutes for the factory data reset and reboot processes to complete.)
Oct 18, 2013 | Casio Cell Phones
Looking remove all stored channels from scanner and start over.
Initializing the scanner will erase all programmed information and return your scanner to its original factory settings. To initialize your scanner:
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" appears on the display.
- Press 0 (zero) while the above message is displayed.
- Press 1.
- Press ENT. "Initializing please stand by" appears on the display.
DO NOT power the scanner OFF until the initializing process is complete and the display shows "M000 Bank0 Ch00"
Bill B.
Listening in professionally since the 60's
Mar 22, 2011 | Radio Shack Pro-2055 Base Scanner
Lambda ews600-18 voltage goes down.
there is a short circuit protection and overoad protection to smps so o/p capacitor may short or secondary diode may short .so check voltage at primary when switched off after 33seconds whether switching process is going or not for that check dc volt at i/p capacitor then check volt at collector of transistor if metr shows 1digit then switching is going if not then meter shows full dc volt check component near about that
Apr 13, 2010 | Lambda 40-Watt Power Supply
My 50 in plasma has seven red lights flashing please help
If it is blinking red 7 times, and then repeating that would be error code 7 (8V6 supply). Power supply
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Oct 24, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Unable to initialized
"Unable to Init" indicates a mechanical error, unless you're able to find a stuck paper or parts of a stuck paper or similar, you'll have to send the unit to service to have it fixed.
Jun 03, 2009 | Brother MFC-5840CN All-In-One InkJet...
SCANNER FAILURE
This is probably a power issue. If you have many devices plugged in to one socket, the printer can't get enough power to start up or start the scanner. If you have a power extended cable, remover it and plug in te printer direct in the wallsocket.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Error 2210
Ink Supply Station failure
The possible cause could be:
1. Reading, writing or initializing the backup EEROM failed.
2. One of the out-of-ink sensors (located in the Ink Supply Station)
is not reporting what it should during the initializing process
while depressurizing.
Corrective Action: Replace the Ink Supply Station
Aug 29, 2008 | HP DesignJet 500ps InkJet Printer
Initializing... RAM CHK
Power supply is defect.
Probebly 2 ELCO's are exploded or ball.
Greatings,
Wim
May 27, 2008 | OKI B4350 Laser Printer
DC power supply HP 6654A
This indicates a failure during Power-on Self test that there is a fault with the DACS or secondary VDAC/IDAC readback.
If a simple on/off cycle of your power supply doesn't resolve the problem, your supply will require servicing.
Nov 12, 2007 | Computers & Internet
HP OfficeJet G85 All-In-One InkJet Printer Logo
338 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
