Problem for Back Massagers
Generic problem for all Back Massagers
Where can i get an instruction manual for...
where can i get an instruction manual for my igia electrosage 8?
Popular Solutions for Back Massagers
Questions and Unsolved Problems for Back Massagers
best back massager hand held?
need power adaptor for back massager serial number t4245333
My fir far infrared body suit is comprised of a jacket with two wires attached to it and trousers...
(More)
My fir far infrared body suit is comprised of a jacket with two wires attached to it and trousers with two wires attached to them as well. It has a control unit with four plugs for the wires to be put into and it has four lights that light up when the unit is heating up. I have had this for 5 months and now the light for one wire on the trousers won't stay lit and it won't heat up either. I need to know if it is fixable and how to fix it if that's possible. I am afraid to use it because of this even though the other 3 parts of the suit work. It is made of polycarbon material like the kind the astronauts use, and it has vinyl inside where the body touches. I am not sure if I cut open the material to check the wires and fix whatever is wrong that I can safely operate the suit again because of the possibility of sweat getting into the wires. Do you think it would be safe to do this? I can't afford another one and I really need it because it really helps me with pain management so any advice would be greatly appreciated. Thankyou so much for your time and effort!
I have an older Htt 10 crpb massage chair, it quit working over nite and when you disconnect the...
(More)
I have an older Htt 10 crpb massage chair, it quit working over nite and when you disconnect the hand held control the chair beeps. when you plug it back it stops beeping but no power to hand control. any ideas
hair got stuck in mechanism. Makes loud vibrating noise
