How do I remove the display screen from an Acer Aspire 6930-6235 laptop? I have taken all the visible screws out but the bezel won't pop out at the bottom (where the hinge is). There appear to be more screws behind the bezel.
Unfortunately there is no manual from acers site on this laptop so it would be hard to tell.
If your trying to remove the plastic bezel just above the keyboard, there can be screws on the narrow side on the back, screws on the bottom of the laptop combined with plastic clips along the edges of it. Also could be screws behind battery if its located at the top on the back. I use these flat plastic tools for taking apart phones and mp3 players they work great for laptops
I just watched a youtube video showcasing the laptop and just watching that I would say there are screws under the battery. With the LCD closed you will probably have to unclip the bezel from the back end of the laptop as well as with the LCD open there are probably a lot of clips a long the edge.
Screws first then along the narrow end on the back then the rest of the clips should be easy to pop.
drive does not operate, computer shows that the driver is present but when you put in a disk the...
(More)
drive does not operate, computer shows that the driver is present but when you put in a disk the drive starts and then stops
Broken power jack on Acer laptop 5735 MS2253 Replace it myself instructions or advice Maintenance...
(More)
Broken power jack on Acer laptop 5735 MS2253 Replace it myself instructions or advice Maintenance manual showing detailed instructions for disassembling this laptop would be excellent. Source of replacement jack would be nice as well.
