Question about Compaq Deskpro EN FC 6450+ Model 10000 (129279-052) PC Desktop
Repiring when start the PC red light blinking every 2second & more.mother board discription was found power crowbar faulty(if aplicable).but i dont find on mother board crow bar section.please help me
  • shankar pandit Jan 04, 2008
    compaqdesproEN,815motherboard,red light blnk.power crow bar problem(if aplicable).how to repair this problem
Your motherboard is faulty. replace.
Posted on Jan 04, 2008
Olivia 242-T11 MOTHER BOARED HAS 2 BLINKING RED LIGHTS WHAT DOES THIS MEAN?
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 23, 2014 | Olevia LT37HVS 37 in. LCD HDTV
Health lights blinking red
You say the "health lights" blinking red. If this is the power light on the front then it can blink at different rates:-
Flashing red (2 blinks) Thermal event (THERMTRIP#).
Flashing red (3 blinks) No CPU.
Flashing red (4 blinks) Crowbar.
I'm not quite sure what they mean by "Crowbar"
The user manual can be found on this link:-
http://h20565.www2.hp.com/portal/site/hpsc/template.BINARYPORTLET/public/kb/docDisplay/resource.process/?spf_p.tpst=kbDocDisplay_ws_BI&spf_p.rid_kbDocDisplay=docDisplayResURL&javax.portlet.begCacheTok=com.vignette.cachetoken&spf_p.rst_kbDocDisplay=wsrp-resourceState%3DdocId%253Demr_na-c00448584-2%257CdocLocale%253Den_US&javax.portlet.endCacheTok=com.vignette.cachetoken
whilst the link below gives you a list of the available documentation for download:-
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/manualsResults?sp4ts.oid=501887&ac.admitted=1403517641801.876444892.492883150
Jan 18, 2014 | HP ProLiant ML110 G3 Server
Hp pavilion a820n comp won,t turn on . rear power light blinking , turned all power off several times waited long intervals before repowering unplug all plugs and tried still no power up found when mother...
make sure nothing is plugged in to your front card readers slots:
If so PC will not boot. Other then that can you put a different power supply in it? Just to see if it is the Power supply..
Jul 26, 2010 | HP Pavilion A820n (PP165AA) PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Comes on but then goes right back off and power light blinks red and green
hi. this is a main mother board issues with a number of circuit component failures. the power section of this unit is safe but, the main assembly will need to be repaired. the quick shutdown is signaling merging circuitry, due to a heat related issue.
This can be fixed by replacing the entire mother board in this unit.
May 18, 2009 | Sony Audio Players & Recorders
Gateway GT5014 will not boot.
Ok, this is a mother board issue. the entire mother board seems to be malfunctioning. the blinking amber/green light is confirming this. the mother board may have some fried circuitry and it will have to be replaced in this situation.
I would recommend extracting the mother board and stripping it. look for any discoloring factors that will lead to a burn out location. this will direct you to the necessary repair zone.
Please rate and have a great day:)
May 13, 2009 | Gateway GT5014 PC Desktop
Gateway mother board
that means that the mother board either doesn't support the ram or the ram isn't working
May 16, 2008 | Gateway GT4022 PC Desktop
Power supply
A crowbar or crowbar circuit is an electrical circuit used to prevent an overvoltage condition of a power supply unit from damaging the circuits attached to the power supply. It operates by putting a short circuit across the voltage source, much as if one dropped a tool of the same name across the output terminals of the power supply. Crowbar circuits are frequently implemented using a thyristor (also called an SCR) or a trisil or thyratron as the shorting device. Once triggered, they depend on the current-limiting circuitry of the power supply or, if that fails, the blowing of the line fuse or circuit breaker.
A crowbar circuit is distinct from a clamp in that, once triggered, it pulls the voltage below the trigger level, usually close to ground. A clamp prevents the voltage from exceeding a preset level. Thus, a crowbar will not automatically return to normal operation when the overvoltage condition is removed; power must be removed entirely to stop its conduction.
The advantage of a crowbar over a clamp is that the low holding voltage of the crowbar lets it carry higher fault current without dissipating much power (which could otherwise cause overheating). Also, a crowbar is more likely than a clamp to deactivate a device (by blowing a fuse or tripping a breaker), bringing attention to the faulty equipment.
The power supply is bad. I would not try to fix it.
Mar 01, 2008 | Compaq Deskpro EN PC Desktop
Compaq Deskpro EN FC 6450+ Model 10000 (129279-052) PC Desktop Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
