Casio FX-300MS Calculator
Problem for Casio FX-300MS Calculator
How do you put casio fx-300MS in degrees mode?
By goodmanapril on Nov 04, 2009
how do you put casio fx-300MS in degrees mode? please help
Solution #1
posted on Dec 06, 2009
Not Rated)
k24674
Rank: Guru  Casio Office Equipment  Expert
Rating: 88%, 797 votes
To change the default angle unit, you press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Grad appear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press the number key corresponding to your case, 1. All angle values you feed the trigonometric functions will be considered to be in degrees. If you use the inverse trigonometric functions to find angles, the results will be in degrees.
Hope it helps.
Thank you for using FixYa and do not forget to rate this free solution.
Was this helpful?
Yes
No
Popular Solutions for Casio FX-300MS Calculator
Questions and Unsolved Problems for Casio FX-300MS Calculator
Do you recommend Casio FX-300MS Calculator?
Answer
Answer
I need help solving a logarithm with my el-520w
Answer
how do i calculate fractional ratios , what key do i use
Answer
All of my answers are coming out rounded, how do I change that?
Describe your Calculators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Calculator Experts
Top Copier & Fax Repairmen
in Van Nuys, CA
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
