Have XAS 146 atlas Copco Compressor. Have to remove front timing case cover to repair oil leak/replace gasket. Timing cover moves back approx. 1cm then stops. is there any tensioner or oil pump components stoping it from comming forward?
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is...
(More)
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
How do I remove the rod from the crank and the crank from the electric motor? Head, cylinder and end...
(More)
How do I remove the rod from the crank and the crank from the electric motor? Head, cylinder and end cap have been removed. There is no "traditional" rod cap. Does the crank housing remove from the electric motor housing?
I have three compressors. Two are oiless and I forgot to check the oil in this one after I moved...
(More)
I have three compressors. Two are oiless and I forgot to check the oil in this one after I moved this year. I started the compressor and ran it for a few minutes without any oil in it. It now turns on but doesn't fire up. Did I destroy it completely? I'm not sure if its woth fixing. thanks
I need diagrahams on setting up a 150 gallon aquarium(glass) no holes in bottem everything has to...
(More)
I need diagrahams on setting up a 150 gallon aquarium(glass) no holes in bottem everything has to come up on left . Have skimmer, wet dry, inline heater , ulerviolet sterilizer , what size of pump and kind should I but and How do I plumb. ?need help Dee
