Question about Canon PowerShot SD600 Digital Camera
Lens problem I dropped my canon on a hard surface from about 2 feet. It will not close and I get the restart camera message... The lens are blocked and on the screen I have: Lens error...restart camera. What should I do ? I don't trust the services from my country and I wish to fix it my self but I need some help please ...
  • 104 Answers
Sir this problem is most common one .but it needs to be done by
sophisticated tools and well trained technicians.
here whole lens system has been damaged.
if lens(inner glass) is broken then it must be sent to authorised service centre.
Posted on Mar 06, 2008
6ya staff
SOURCE:
Screen says lens problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism (look closely for sand particles around the lens barrel of your camera. A single grain of sand can jam in the gaps around the barrel, preventing the barrel from closing. Use air or a thin sheet of paper to dislodge them). Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 22, 2010 | Canon PowerShot SD1000 Digital Camera
My canon powershot a590 camera lens is stuck. When I attempt to start my camera I get a message saying Lens Error Restart Camera then the camera immediately powers off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Feb 07, 2010 | Canon PowerShot S2 IS Digital Camera
Canon ixus 60 - lens error restart, restart camera
Dear God, It was like a comedy. I got on the whale boat, after having the Canon ixus 60 for 4 years. I've never had any error messages. The whales came 10 feet from the boat and twice raised their head, and no camera, just the beeping and the error message: lens error; restart camera. How do you restart the ixus 60 Canon digital camera, anyone? Please help!! Thanks [email protected], Maui, Hawaii. Aloha!! & Mahalo.
Aug 26, 2009 | Canon Cameras
My wife dropped our Canon A470 camera on a concrete surface. The camera will turn on but it displays a lense error message asking to restart camera.
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 29, 2009 | Canon PowerShot A470 Digital Camera
"LENS ERROR, RESTART CAMERA", THIS IS NOT WORKING.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 20, 2009 | Canon PowerShot A540 Digital Camera
Lens wont close.
did you try and take the battery out and outting them back in
might be worth a try
Feb 08, 2009 | Canon PowerShot SD850 IS Digital Camera
I have canon cameral model sd 700 whose lens will not close.  i get the message to restart but repeated on and off will not restart; what shall I do?
Jan 22, 2009 | Cameras
Canon sd 600
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Jan 04, 2008 | Canon PowerShot SD600 Digital Camera
Lens error
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 09, 2007 | Canon IXUS V2 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
