These regulators can usually be purchased from Canadian Tire or Home Depot. If you are unable to locate the exact replacement, email the model number located on the regulator and I will locate one for you. I am in the GTA and can be contacted via company website. www.emshvac.com
But one question, why do you think the regulator is defective? These rarely fail.
Was this helpful?
Yes
No
Popular Solutions for Endless Summer ES92000 Patio
When the furnace is running the light comes on, lights all 4 burners but only lasts a couple...
(More)
When the furnace is running the light comes on, lights all 4 burners but only lasts a couple seconds. This goes on the entire time it is running. Took off the door and followed directions to turning switch to off, leave for 5 min. turn on, replace door and set therm. to low heat. have done all this and as soon as the fan kicks on the flames go out.
I have a 2 year old natural gas, forced air heatinig system. My thermostat is set at 68 and the room...
(More)
I have a 2 year old natural gas, forced air heatinig system. My thermostat is set at 68 and the room temp is only 62. When I woke up thin morning I took the thermostat (honeywell digital) off of the wall and when I put it back on the wall the heating unit automatically turned on. This has happened several times where I had to either reset the thermostat or the system. Can someone tell me what the problem could be?
have a fraser johnston dual rooftop. The burners keeps cutting out every 20-30 second, pilot is on...
(More)
have a fraser johnston dual rooftop. The burners keeps cutting out every 20-30 second, pilot is on constantley, what is the problem?
Full tank of propane and it will not light except with match and when you try to go off pilot it...
(More)
Full tank of propane and it will not light except with match and when you try to go off pilot it goes out completly, How do i fix it
