Question about Samsung HLN617W 61" Rear Projection HDTV
PLASMA Y-DRIVE 2yr old Samsung (electrograph) R4252, No picture, sound OK. All PS voltages good to the X-drive and Y-drive boards. After about 5min the X-buffer IC's get hot and start popping/burning.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Most times with this happens you can repair it by replacing the buffer bds. Sometime the ysus bd is bad and unfortunately the panel can cause this problem. I would say 60% of the time the buffers will correct the problem. I usually replace both at the same time.
Posted on Feb 21, 2008
6ya staff
SOURCE:
I have a 46 inch Samsung plasma HP R4252 picture went black
Probably the power supply that drives the video has gone bad. Samsung recommends the TV go to a service center. If you have some skill and are willing to try, open up the back of the TV, remove the shielding and look at the boards to identify any obvious damage. Leaking or bulging capacitors, soot, scorch marks are the obvious. (Other parts can have bad solder or tiny cracks that are hard to spot.)
http://www.shopjimmy.com/catalogsearch/result/index/q/HP-R4252 has reclaimed parts for this TV. These are parts from TVs that were damaged in shipping and were only run during quality control tests. They list several power supplies for the model so check what part number is actually installed (there is usually a label on the board).
I hope this helps.
Aug 01, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Short circuit on the "Y" sustain board
The problem is heat!!! If the tv has fans they should be checked for normal operation,although on the early samsung models there were none, and the problem is that the panel drive buffers are getting to hot due to inadequate cooling. This is most apperent when tv is mounted to close to the wall, also external fan blowing on the rear left side will dissapate the heat. It is a problem on early Samsung and Electrograph 42 " plasma models. Hope this helps.
Jul 28, 2010 | Samsung Televison & Video
I have a samsung HP-R4252 42" Plasma which is over 3 years old and 3/4 of the picture is covered in lines and the color is predominately red, any help?
REPLACED Y BUFFER BOARD
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY LJ92-01203A
Nov 02, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I have one Samsung HP-R4252 no give video and sound, I check all fuse it's good, check all voltage are good, only turn on the led in power button and flashing when press any key in the remote control, I...
try replaced main Y assy board or power supply board
Manufacturer Samsung Part Number BN96-02033A Description ASSY PDP P-Y MAIN BOARD
Manufacturer Samsung Part Number BN96-02213B Description ASSY PCB P-SMPS
Sep 03, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung PS-42S5H
Since you smell it above one side of the panel I will guess the right side (from the front). This is where the Y Sustain board is located, it has large heatsinks over the drive ic's to dissapate heat. If the ic's are bad this is more than likely the smell. This board controls the scan of the picture and drives the plasma panel. I would definatly have a technician look at the unit, these are normaly econimical to repair.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Electrograph DTS4225PTD Plasma TV 42"
It's Y upper buffer, also cross matches, with LJ41-02760A which is for Samsung 42 Plasma
Feb 29, 2008 | Electrograph Systems DTS4225PTD 42 in....
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
R4252 No picture, sound OK Y-Drive buffers overheating
Try to replace the Logic Board, about 50% chance to fix the problem.
Jan 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
107 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
