Question about Disney Mix Max Digital Media Player
Pirates Of the Caribbean Mix Max not working
After I had downloaded a video clip to my Mix Max, It whent just to a black screen and if I try to turn it on nothing happens.
Try using a pin to push the tiny reset button on the bottom of your mix match.
Posted on Jan 11, 2008
Need manual for Mega Bloks - Pirates of the Caribbean At Worlds End
The Pirates Peril Set is actually a combination of 3 sets Black Pearl, Bucanneer's Hideout and Danger from the Depths (1066, 1079 and 1086).
The Mege Bloks wiki, Blok City, has a combined set of instructions for this set. If you follow the link below and then go to the bottom of the page you'll find the instructions.
http://www.blokcity.com/wiki/index.php?title=1091_Pirates_Peril
Alternatively of course you could download each separate instruction book for the 3 sets.
May 22, 2011 | Mega Bloks - Pirates of the Caribbean At...
I have age of pirates caraibean tales but i just cant play it on windows 7.What should i do?
You need to patch it to work with Win 7. This should do it:
http://games.softpedia.com/progDownload/Age-of-Pirates-Caribbean-Tales-15-Patch-Download-12782.html
Just remember to download with care :)
May 07, 2011 | Atari Age of Pirates: Caribbean Tales for...
I have engine.exe error when i try to run Pirates of the Caribbean for PC What can i try to do?
Hello Etto!
Recently i had the same problem with this game. However, in my case i finally managed to solve it! I guess, the main problem was, that the game couldn't communicate with my Intel on board graphic card, what is more, it didn't see my AMD Radeon video card. Finally i found 2 soultion:
First: swich off Intel on board graphic card. This way the game used my AMD Radeon video vard without any problems.
Second: Use a software, called SwiftShader2.0, which can make the game use the Intel on board graphic card without any problems.
You can download SwiftShader2.0 from here: http://www.moddb.com/mods/new-horizons/downloads/swiftshader-v20-demo
Having downloaded, sipmply install it to the root folder of the game (in my case it is C:\Program files\Bethesda Softworks\Pirates of the Caribbean)
Note that, there is a "Config" file in this root folder, and using that you can make the graphical settings of the game (resolution, set it to full screen mode, etc.). For some reasons this didn't want to work in my case, but there is an other way of doing these settings: in this root folder you can also find an "engine.ini" file, which can be opened as a .txt file. If opened as .txt, than you can rewrite the data in it, in order to make the desired changes (for examlpe you should rewrite "full_screen = 0" to "full_screen = 1", to activate full screen mode. You cn also chage the graphical resolution of the game this way.)
If necessary you can easily reinstall SwiftShader2.0, using its reinstall icon, that can be found in the same folder, in which it was installed.
The link i have given to download SwiftShader2.0 is originally a created for "New Horison", which is a promising mode for Pirates of the Caribbean. You can also download the full mode, and install it containing SwiftShader2.0. This may also solve your problems, because as far as i know the developpers of this mode made it work on modern systems. What is more, this mode contains much more adventure -for example you can choose from about 7 very different charachters to play with! But personally i decided to play without whis mode, because in my system it wasn't performing well, and anyway, i wanted to play with the original game.
I hope, this will solve your problems. /Sorry for spelling mistakes/
Mar 07, 2011 | Bethesda Softworks Pirates of the...
Pirates of the Caribbean engine.exe error
Pirates of the Caribbean problems with ENGINE.exe: In my case a simple software, called SwiftShader2.0 solved it!!!
Recently I also had a problem with this game. Every time i tryed to start a new game, an error occured, stating, that the engine.exe stopped, and the program exited. After spening all night researching on this topic, i found the solution: you should install SwiftShader 2.0. It is a simple and great program (as far as i know it changes the graphical performance, in order to get the game work).
You can download it from here: http://www.moddb.com/mods/new-horizons/downloads/swiftshader-v20-demo
Note that, there is a "Config" file in this root folder, and using that you can make the graphical settings of the game (resolution, set it to full screen mode, etc.). For some reasons this didn't want to work in my case, but there is an other way of doing these settings: in this root folder you can also find an "engine.ini" file, which can be opened as a .txt file. If opened as .txt, than you can rewrite the data in it in order to make the desired changes (for examlpe you should rewrite "full_screen = 0" to "full_screen = 1", to activate full screen mode. You cn also chage the graphical resolution of the game this way.)
The link i have given to download SwiftShader2.0 is reliable, it is originally a created for "New Horison", which is a promising mode for Pirates of the Caribbean. You can also download this full mode, and install it containing SwiftShader2.0. This mode contains much more adventure -for example you can choose from about 7 very different charachters to play with! But personally i decided to play without whis mode, because in my system it wasn't performing well.
I hope, this will solve your problems too. /Soory for spelling mistakes/
Aug 26, 2010 | Bethesda Softworks Pirates of the...
WHERE CAN I GET THE MANUAL FOR PIRATES OF THE CARIBBEAN BY BETHES
You can buy manuals and boxes for video games at the following link.
http://shop.vendio.com/bregamesmmcm3/store.html?search_cmd=1&words=pirates+of+the+caribbean
The page you'll reach with this search will show you all the items they have for "pirates of the caribbean." You will need to find your exact game and platform. Good luck!
Jan 04, 2009 | Bethesda Softworks Pirates of the...
Can't get the Mix Max to turn on at all...
Try connecting the player to your computer and press the reset button. You'll need a paper clip or thumb tack to reset it. Then remove the clip and try turning it on. Also as a general rule it's always best to insert and remove the clips when the player is turned off.
Oct 09, 2008 | Disney Mix Max Digital Media Player
Blank screen and weird noise
You can try the instructions located at the link below to try flashing the internal firmware of the player and see if that corrects the issue. If that doesn't work I'd suggest contacting Digital Blue for warranty replacement.
http://digiblue.com/customer-service/faqs/disney/mixmax/MixMaxFirmwareUpgrade.doc
Jul 25, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
97 people viewed this question
Top Disney Audio Players & Recorders Experts
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
