Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby Diamond Edition
How do I change the toothed drive belt that propels the hoover...not to be confused by the roller drive belt
  • Anonymous Mar 29, 2014
    the belt that drives the roller
Does not **** but brushes turn
Posted on Oct 15, 2008
How do i assemble the fluffy portion on the kirby cleaner
Posted on Sep 20, 2008
    President:
  • 1,673 Answers
If this is a Hoover vacuum, which model is it?
Posted on Jan 05, 2008
6ya staff
SOURCE:
Do the belts pull the motor as well as the rollers?
No.
Theres a shaft on the motor to drive the roller, belt connected to it.
Electrical power drives the motor, which in turn will spin a Brush Roller.
Some vacuums may have an additional roller to a gear system to power self propel.
Others, like a Kirby, have a separate Geared 'Transmission'.
Jun 01, 2015 | Vacuums
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
I have a Kirby G series diamond edition. There seems to be no suction when I turn on the vaccum. The bag inflates, but the roller does not turn. It has a new belt and the roller brush is clean. Any...
THE IMPELLER LOOKS SHOT.. 25 QUID FOR NEW ONE,,LIFT THE LID AND TURN THE ROUND PIN AND CHECK FOR RIDGES ROUND THE WHITE IMPELLER,,IF NONE THERE THATS IT,, HAPPEND TO ME TEN MINS TO FIX GEORGE
Jun 02, 2011 | Kirby Ultimate G Bagged Upright Vacuum
How to change belt on the kirby ultimate g series diamond edition?
Hi There,
Here's a very helpful video that we've shot showing you exactly how to replace the belt on a Kirby Generation series, including your Ultimate G. The video also shows you how to perform basic maintenance on your roller brush to prolong the life of the belt as long as possible. If you haven't already purchased a belt, and need to buy a new one, here's a link to the exact belt that's used on your repair:
Kirby Generation Belt:
http://www.govacuum.com/kir184.html
Here's the video:
If you have any follow up questions, please feel free to use the comment section on this repair page, I'm always happy to answer follow up questions.
If this video helped you, please be so kind and rate my repair, or leave feedback for me. This is greatly appreciated.
Chris Jones
GoVacuum.com
May 01, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I have problem with the belt and roller how to put
I read the fixit website about getting the roller off on maybe a newer version of Kirby vacuum cleaner is there a solution for the same problem with the Utimate G?
Aug 17, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Lost my manual
Here is a very important bit of information...how to change the belt! Check out my online guide...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope it helps!
Marci
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Prying out the Roller?
Hi There, There should be no need to pry it at all. The best way to get it out is to pull with either end at the same time and it should pop straight out. Also if the old belt is still on use that to pull the roller out. Many Thanks Chris www.elidistribution.co.uk
Sep 08, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
105 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
