Microsoft Xbox 360 Console
Error e74 on xbox 360
shared by 37 users
posted by alan uridge on Jan 04, 2008
how to fix it
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
36 Other Users Have The Same Problem
Posted by smudie10 on Nov 27, 2008
e74 on screen how do i fix
Posted by Guest on Nov 11, 2008
yep same thing
Posted by Guest on Nov 03, 2008
my xbox 360 has the red lights instead of green, its the error e74
Posted by Guest on Oct 30, 2008
error e74 on my console, too.
Posted by stonedassg on Oct 27, 2008
my x box 360 wont start it just stays on the sytem error e74 screen. how can i fix it?
Best Solution
posted on Oct 18, 2008
FixYa! (100)
frankome1
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
error E74 is showing on my xbox and I'm trying to fix it, please help me.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on error e74 on xbox 360:
I don't want to Accept this solution
Best Solution
posted on May 24, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
open it up and start putting random washers in this is what i did when bottom right hand corner showed up red with an E 74 error now it has been working fine for a year and a half
Thank You!
Best Solution
posted on Mar 28, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
don't do the towel trick
Thank You!
Best Solution
posted on Feb 24, 2008
FixYa! (100)
aa22
Rating: 96%, 7 votes
to prevent it from happening aggain by a fan for the 360
Thank You!
Best Solution
posted on Mar 04, 2008
FixYa! (100)
swift85
Rating: 94%, 5 votes
i have just recently got the error e74 which from various sources leads me to beleive that it is the scaler chip, i have already carried out the xclamp mod, so all i have done is got the wifes hairdryer and heated both sides of the scaler chip moving the hairdryer around in a crcular motion as i did not want melt the plastic parts on the motherboard, once i had done that i turned the xbox360 on and it gave me an overheating error but no e74 error, i left the system to cool down for about 10 mins and tested and all was ok!!!! so all you need is the xclamp mod and a hairdryer!!!!!!
Thank You!
Best Solution
posted on Sep 18, 2008
Helpful (85)
dirtbikekid
Rating: 90%, 3 votes
ok heres wut i did and it worked perfect!!! threw the thing away
Thank You!
Best Solution
posted on Mar 29, 2008
Helpful (85)
Guest
Rating: 0%, 0 votes
try and get 3 red lights and then send it back and get it fixed free!
Thank You!
Best Solution
posted on Oct 25, 2008
Helpful (85)
gamepassion
Rank:Guru Guru
Rating: 85%, 76 votes
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
hope it helps...
Thank You!
Best Solution
posted on Mar 27, 2008
Helpful (85)
Guest
Rating: 0%, 0 votes
just send it back
Thank You!
Best Solution
Helpful (85)
xX_Nem0n_Xx
Rank:Master Master
Rating: 82%, 31 votes
You all are wrong. There is a guide to repairing the GPU on an xbox 360. Yes, the best solution is to just send it back to MS and have them fix it and add there new GPU to it, which has a totally new design including heatpipe technology. But if your like a lot of people (including myself), that have opepned there xbox360 up and voided the warranty, there is a solution to this problem without sending it to microsoft. If you have your warranty still.. Do not continue, the rest doesnt apply to you.
Well, you must have been like me and voided your warranty! Well, lets start fixing your xbox 360!!
Since your AV cable is good, then it definately is your Scaler chip. The only way that you can fix this is if you take your xbox360 apart and resolder the GPU to the motherboard. Now theres about 50 different tutorials out there on how to take your case apart but I found that this tutorial is the best... its straight forward and includes pictures:
http://www.llamma.com/xbox360/repair/Xbox-360-Disassembly.htm
Okay, your xbox is apart. Next, your going to have to remove the x-clamps and GPU. Then you are going to have to resolder the GPU to the motherboard by overheating your GPU. llamma also has a really good write up on this as well. They also sell the tools that you will need, and the washers and bolts you will need.
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
Once you've resoldered your GPU, then you might want to consider installing a CPU fan on your outside case to prevent your xbox from overheating in the future. As of now, you cannot buy the new GPU heatsinks which have the heatpipe technology, so this is the best thing to do for the voided xbox's. Hope this helps
Thank You!
Best Solution
posted on Jan 04, 2008
Helpful (85)
biomed616
Rank:Wiz Wiz
Rating: 84%, 131 votes
If you have tried swapping out AV cables with known working ones, then there is no way for you to fix this issue yourself. MS will have to fix this one there is a problem with your scaler chip / GPU. Sorry there is no do it yourself manual on this. Hope this helps
Comment posted on Jan 08, 2008
There is no how to fix it guide for this error, You have to send it into Microsoft. There is nothing you can do unless you can get your hands on a good GPU and scaler chip find out which ones they are inside the Xbox360 and then replace them.
Thank You!
Best Solution
posted on Feb 25, 2008
Helpful (85)
driftmanager
Rating: 80%, 3 votes
I do not need MS, I have fixed the E74 error myself!
I did not need to replace the scaler, i simply heated it up until it made contact with the motherboard again then i placed a stack of penys on top of the scaler and asembled my xbox again and after just a day or so the pennys pushed the scaler back into place and my xbox is going good for a couple of days now with some overheathing problems but only coz im waithing for thermal compound.
I have placed some videos on youtube to help some gamers with simlar problem get back online, hope it helps some one!
View my solution for E73 Error message here:
http://www.youtube.com/watch?v=S3QYIkVT2lI
View my overheating solution here:
http://www.youtube.com/watch?v=B0OT3-vXOBw
Comment posted on Mar 29, 2008
I HAVE FOUND THE PROBLEMS AND THE SOLUTIONS SEE MY VIDS OF U HAVE THE E74 PROBLEMS
DO NOT PAY FOR VIDS!!!!
http://www.youtube.com/watch?v=J5CoinVyklQ
http://www.youtube.com/watch?v=XdmjdFlrESs
search driftmanager for the rest.
Thank You!
Best Solution
Helpful (85)
Guest
Rating: 0%, 0 votes
wrap it in a towel?
Thank You!
Solution #14
Inappropriate (40)
Guest
Rating: 0%, 0 votes
overheating just send it back!
Thank You!
Solution #15
Not Rated (0)
ababejore
Rank:Wiz Wiz
Rating: 97%, 9 votes
Try this link www.microsoft.com/Xbox360Console
To find your best solution.
9
Thank You!
Solution #16
posted on Sep 10, 2008
Not Rated (0)
C_romon028
Rating: 0%, 0 votes
dude i have lost my warranty will they still take it
Thank You!
Solution #17
posted on Aug 22, 2008
Not Rated (0)
John-Dick
Rating: 0%, 0 votes
Thank You!
Solution #18
posted on Jul 18, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
buy a ps3?
Thank You!
Solution #19
posted on Jul 16, 2008
Not Rated (0)
barryjohn 35
Rating: 0%, 0 votes
send it 2 ms then it will work with no worrys
Thank You!
Can you Help with these Video Game Consoles problems?
i tried hooking up my 360 to my computer but im having...
purchased i-pod from walmart with 2 yr warranty which...
I checked all the connections. There is sound but no...
red flahsing light
my xbox 360 freezes up . now it want even start.
36 Other Users Have The Same Problem - Continued
Comment by alane1974, posted on Oct 16, 2008
One red light in bottom right hand corner, it is an elite model
Comment by ImortalFear, posted on Oct 14, 2008
I also have 1 red light in the bottom corner. Its the elite model, In thought  those werent supposed to break down....=(
My screen turned all black and blue while I was playing Halo 3 online. I restarted it and it said error e74. I tried removing the hard dive and the error didnt even want to show up.The screen just stays blank without the harddrive. iS IT my av cable?
Comment by mc-sel, posted on Sep 17, 2008
e74
Comment by redleader962, posted on Sep 16, 2008
Same as many others. some glitching on screen occasonaly for the past 2 week and on restart E74, never worked again. Dont want to spend a other dime on this piece of xbox 36crap since it is the 3rd time it broke in a year. cd drive, 3 red light of death (MS send me back a "Certified Microsoft Replacement Xbox360 console") and 5 months later E74. Liabilty...
Comment by hurtadoj19, posted on Sep 10, 2008
a red light in the bottom right corner
Comment by Guest, posted on Aug 19, 2008
i have a(e74) and ared light on my xbox
Comment by Guest, posted on Aug 18, 2008
error e74 message phoned microsoft they said hardware failure i think its tv output socket because my screen started having black line`s on it and when i switched my xbox off and on the e74 message appeared
Comment by xMorgan, posted on Aug 16, 2008
I have the error e74. I already know how it works how to fix it how it got like this. I just want to know a way to fix it without opening my xbox 360.
Comment by mikey12321, posted on Aug 10, 2008
i have the E 74 error plzz help me
Comment by coreydow2009, posted on Jul 27, 2008
My 360 has a e74 error on and it has a red light on the bottom right hand side can you help me fix it?
Comment by Guest, posted on Jul 26, 2008
the bottom right light is lighting up red and i don't know what to do please help meeee.
Comment by blue magic93, posted on Jul 11, 2008
one flashing red light.. bottom right to be specific.
error code e 74.
Comment by Guest, posted on Jul 11, 2008
one red ring on the bottom right corner
Comment by mamjaa6, posted on Jul 02, 2008
I was playing halo 3 when mine happened and i am angry ever since please someone tell me what to do because I tried the towel trick and I tried everything
Comment by wolfie873, posted on Jun 26, 2008
My xbox has the e 74 error and I dont know what to do?
Comment by Guest, posted on Jun 15, 2008
i was playing cod4 and it all the sudden it turned red... what do i do?
Comment by Naterbater, posted on Jun 14, 2008
I was playing Tom Clancy Rainbow Six Vegas 2 and pluged the HD cords into the tv switched it to HD and it kept saying system error E 74. We looked on Xbox.com and the steps it told us to do did not work. What do i do now?
Comment by harmonator62, posted on Jun 05, 2008
Happened after a trip out of town and one week after I bought MLB 2K8. The "Error" message screen pops up with code 'E74' and lower right quadrant in red. Tried everything suggested by microsoft but will not pay for repair.
Comment by jakey0313, posted on Jun 03, 2008
one flashing light...it says error e 74 on screen..?
Comment by Guest, posted on May 31, 2008
i keep getting the same error message. what do i do
Comment by Guest, posted on May 08, 2008
I also have the same problem for my 360 and the one red light how do I fix it. Does that book really work showing you how to fix it?
Comment by Guest, posted on Mar 27, 2008
I have the same problem..just got it
Comment by Guest, posted on Mar 09, 2008
I've fixed a few xbox 360s with an xbox 360 repair book. It also came with some videos which made it really easy to fix my 360.
That was about 3 months ago, and it's still running just fine.
Comment by bulpyx, posted on Mar 09, 2008
my 360 has one red light and a e74 message help me
Comment by Guest, posted on Mar 04, 2008
I have the same problem, 1 flashing red light with a red grid like effect on the screen and then it goes to an error page that lists e74. I;ve tried the unplugging power off/on etc. but it has not helped. Suggestions, Thanks
thanks for this
Comment by gaddis, posted on Mar 04, 2008
hi my 360 started to get a grid like effect .then the bottom right red light started to flash.and then the screen went blank then came up with e74.please help or my kids will kill me regards gareth
Comment by Guest, posted on Mar 03, 2008
Comment by driftmanager, posted on Feb 20, 2008
I have the E74 error message aswel i have now tried every hint and trick on the net to fix it accept replace the ana (scaler) chip, or the gpu which i dont think it is as im sure its the graphics. if anybody knows about a guide or any helpful knowledge on how to do this please post here.
Comment by jakdawson, posted on Feb 20, 2008
e74
Loading problems.
Repair Service
Find Video Game Console Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
