Question about Panasonic AG-DP800H Camcorder
Problem Supercam AG-Dp 800heg
I have probleam with my camera Supercam AG-Dp 800heg.
I describe you that when recording start on my camera there was a lining shown in my camera viewfinder and also in recording. But when camera has been started about 5 or 6 minutes lining which is shown on viewfinder has less but not remove completely and when we play the cassette after recording lining has also shown. When we setting pedistal setting in my camera menu setting up down line also shown up down but not completely remove lines. So please solve my probleam. I am very much glade if you help me to solve this probleam.
  • Kinbolo Jan 13, 2008
    Lines appear on the view finder when the camera is switched on. Before I begin to record I have to turn the camera on for about 15 minutes then the lines disappear. A technician told me it may be that the pulse power board may need replacing. Is he correct or is there another solution. I searched online for this board but cannot find it. If you can locate it please let me know the part number so that I can have this problem solved.
Hello Situ,
If you must Change the erasing head's supply filter (capaciter) then change the audio erasing Bios OSC, transformer supply filter tantlem capaciter, the problem will be clear.
Regards,
Muthu.M
myesak_14@yahoo.co.in
Posted on Jan 04, 2008
I am a electronics technician and have repaired about a dozen supercams with this same problem.
the problem is the .33 capacitors on the main board. there are about 60+ of these tiny capacitors and they will need to be replaced if your cam has over 2000 hours of being powered up.
Posted on Sep 19, 2009
    Champion:
  • 221 Answers
Lines in the viewfinder of the supercam until it's warmed up is an indication of defective surface mount electrolytic capacitors on the video board in the camera. I have done several; be careful not to damage the board if you try it yourself.
Posted on Feb 18, 2008
AG-DVC30 "no tape in camera" error message
thats probly the cass in swicth
or a dirty sensor....
hope that will help..
Mar 01, 2010 | Panasonic AG-DVC30 Mini DV Digital...
Error message "Can not find camera.Please connect Omnivision SuperCam!" on my Vista laptop. Scanner works fine on my friend's XP desktop. Have tried all steps outlined in manual (several tim
On my Vista desktop it worked directly, but I had the same error message on my Vista laptop when the scanner was connected through an USB hub. Perhaps the power is not sufficient?
Then i plugged the connector directly into the laptop usb port 2.0, and the driver was automatically installed and works fine!
May 10, 2009 | Office Equipment & Supplies
Supercam ah dp800h powers on but nothing in the view finder
most likely problem is many defective capacitors on the video board.
Mar 02, 2009 | Panasonic AG-DP800H Camcorder
This camera is making a sound when recording and also the lens has devloped some fuzz inside. Please let me know where they can service and clean lens out. Also I need an to purchase a new battery. Thank...
the sound you refer to during recording on the ag-456up is probably bad bearings on the video head. unfortunately, this part is no longer available. any good electronic repair shop should be able to clean the lens. a new battery should be available from wal-mart, circuit city, best buy, etc.
Oct 15, 2008 | Panasonic AG-456 Camcorder
AG-DVC7
take the tape out of the camera. you don't need to put a tape in the camera if you are not recording in the camera.
Apr 20, 2008 | Video Cameras
Time / Date Generator
try replacing the lithium battery that provides backup power to the clock.
Jan 19, 2008 | Panasonic AG-DP800H Camcorder
Lines in AG-dp800h
Hello all!!
I found the solution!!
3 electro chemical capacity in the 3700 series on the camera head board.
change the chemical rear the DAC and above the ADC for process digital signal.
The name of the capacity: c3 c6 c9 in the 3700 section on process board.
The capacity is a part of filter the reference signal out of the DAC for ADC reference for ic1 ic2 ic3...
If the capacity is dead a sinusoidal signal appear for the red blue and green reference voltage and the result is a parasit signal into all camera.
You can measure a 50khz signal on the composite video signal.
Best regards
Phil_F
Jan 13, 2008 | Panasonic AG-DP800H Camcorder
Panasonic AG-455 Problem
The noise is most likely bad bearings in the video head assembly. No longer available from Panasonic. The b/w recording problem is most likely caused by a bad video board inside the camera. Unfortunately, the video board is also no longer available.
Oct 27, 2007 | Panasonic AG-455 Camcorder
Panasonic AG-DP800H Camcorder Logo
318 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
