Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
I have a samsung side by side fridge, and...
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
Solution #1
posted on Nov 03, 2009
Rank: Guru
Rating: 91%, 642 votes
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Popular Solutions for Coffee and Espresso Makers
Braun Tassimo Espresso Machine & Coffee Maker
1 Solution
Questions and Unsolved Problems for Coffee and Espresso Makers
which style of the bodum french press' is best, the chombard, brazil, or kenya?
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
Why does the Vigano 2-cup stove top coffee machine explode even when it is already passing water...
(More)
Why does the Vigano 2-cup stove top coffee machine explode even when it is already passing water through the coffee grinds. Operating ''normal'' but suddenly exploding at the flat base line.
Starting for first time - small cup blue light never flashes - both cups just solid blue. I pushed...
(More)
Starting for first time - small cup blue light never flashes - both cups just solid blue. I pushed small cup - nothing happens???
I got a Soltaire BOSCH Coffee and Expresso Machine where I lost the instructions to clean it with...
(More)
I got a Soltaire BOSCH Coffee and Expresso Machine where I lost the instructions to clean it with the tablets. Please, advise me on instructions on how to ckean it, as I see in the screen "Declacify" notice which does not move away even after I clean the machine Ibrahim alhammad_2000@yahoo.com
