Hi, I have an Intel q965gf motherboard with 4 DIMMs which will support 8GB of memory at a max of 667 MHz or 4 GB of memory at 800 MHz. Which of the above would be best to do for gaming performance? In the specs for the board ( under supported memory configurations), it says that the largest usable DIMM for DDR2 at 667Mhz is 2 GB, thus 4 DIMMs x 4 = 8 GB. It also says that the largest usable DIMM for 800 MHz is only 1 GB, thus 4 x 1 GB = 4 GB max for 800. What would happen if I put 2 x 2GB at 800 Mhz modules into the first DIMM of each channel (ie. do I have to buy 4 x 1 GB modules of 800 MHz to get 4GB or could i install 2 x 2 GB of 800 MHz?) Thanks in advance. Thanks
I don't think a difference of 133MHz of memory speed will make a difference in your gaming performance either way. Also, you won't be able to use more than 3.5GB of memory if you don't have a 64-bit operating system. Finally, it'll be a rare person who actually notices a difference in using 8GB vs 4GB of RAM. So, in conclusion, just buy 4GB of 800MHz RAM and spend your money and your time on a good graphics card, if gaming performance is your main concern. If you have any further questions, contact me through http://www.inovagent.com.
If only using 32 bit OS, then go for faster memory speed. More important than just MHz ratings, is the CAS times, lower numbers are better. All 800MHz memory can operate at 800MHz, but some can retrieve the data faster than others, reducing the delays a little.
