Question about Mpio FL300 MP3 Player
No Light on My MPIO FL300
There is no light on my mpio fl300 when I play it.
  • S A M Jan 04, 2008
    still having problem................................no reply from ur side
    this is very bad.........try to fool people here
  • Anonymous Feb 26, 2008
    when I ignite my fl300 I do not visualize the screen,
    but I read without light:
    "warning no flash"
    As we solved this problem?
I have the same problem. I can store things in it but can't see the screen. the LED seems to have died first the light went out then it just died.. This is the 3rd Mpio FL300 that did that to me. I returned the 2 others before the warranty was out but this time it's to late. how do we fix this problem in other words how do I get the led to work????????
Posted on Feb 25, 2008
I found a Mpio Fl300 player. I cannot use it because I think I need a software for it I'm guessing Where can I obtain one Thanks
now they have the fl300 and i cannot tell for sure what type of usb connection it has. As it shows on the website that there is a special usb connector the goes from usb-1/4" audio jack. But it also says it has mini usb connection. The device is listed as plug and play so if you plug it into your computer with the proper connection it will automatically connect and allow you transfer files. if it does not pop up then it is most likely the product is damaged. here is link to there website. The website is only in Spanish. http://es.mpio.com/product/productview_fl.html?view=a
Aug 17, 2010 | Mpio FL300 MP3 Player
I cant seem to fine out how to charge my mpio
do you have your USB cable? keep it connected to your computer that helps you to transfer files and charge it. device ill tell you when it's fully charged actually there is no charger for it.
if you need to read about it here is a link:
http://www.mpio.com/product/productview_fl350.html
if it works for you don't forget to rate me
thx
Apr 29, 2010 | Mpio FL300 MP3 Player
I tried turning my mp3 player on and it said "invalid memory, cant find MBR"
Invalid MBR = Invalid Master Boot Record.
This means that your player Flash Memory drive is corrupted and unfortunately may need to be reformatted if you cannot repair it using some Disk drive or Flash drive utility.
You can try to use 'Properties -> Tools -> Error Checking -> Check now' to fix the issue.
If you have a backup of the music on your player, I would simply use Windows Explorer and FORMAT it using FAT32.
Hope it helps.
Dec 22, 2009 | Mpio FL300 MP3 Player
How to Replace Battery in MPIO FL300
my mpio FL300 can't conected to my computer,because i've been format it.how to solve this problem?thx.(if ful)
Aug 16, 2009 | Mpio FL300 MP3 Player
My mpio player does not come on. When I press the power button only the blue light is lit and it does not go any further. please help
hello.
your chances are:
1st it is broke and still can be used as a small portable drive(like a tumbdrive) after you have formatted it..
2nd: it is facing internal software problems.
you will have to format it though, but before doing so, copy all the mp3s you don't wont to miss from it.
get the MPIO Manager 2 from
http://www.mpio.com/product/productview_fd100.html?view=d
-then format the player and reinstall the firmware using the manager( you will have to install it on your pc first)
- put some mp3's onto it, unplug from PC
and hit the play button. good luck!
Aug 04, 2009 | Mpio FD100 (128 MB) MP3 Player
How can i delete files wuthout the software?
MPIO Utility can be used with MPIO player that supports USB Mass Storage.
With this, you can..
- Format and Recover MPIO player
- Upgrade firmware of MPIO flash-type player
- Building playlist of MPIO hdd-type player
* Supported OS : Windows 98 SE, ME, 2000, and XP
* MPIO Utility doesn't work with FL200 and FY300.
* If you are using the latest firmware, be sure to use the latest version of MPIO Utility.
* Please uninstall the old version of MPIO Utility before installation.
[Download]DOWNLOAD NEW DRIVERS AFTER UNINSTALLING OLD ONE'S RICHARDM69
Dec 04, 2008 | Mpio FL400 MP3 Player
Hi, i dont have the disc that comes wuth tho mpio. how can i delete files that i recorded on it?
[Download] REDOWNLOAD NEW DRIVERS AFTER UNINSTALLING OLD ONE'S RICHARDM69
Unreadable directory by recent windows XP laptop
[Download]You can redownload drivers and first uninstall the old one's.RICHARDM69
Sep 25, 2007 | Mpio FL400 MP3 Player
Won't turn on
either you got a faulty surface mount regulator IC or you got a corrupted flash memory. Try pressing play button, then alternately press volume down (-) and Rewind (<<) buttons. When the "FORMAT? Press Menu" appears, press MENU BUTTON. A LOW LEVEL FORMAT will be in progress. When it's done, reload firmware recovery using MPIO Utility. If however you nothing appears on the screen afteryou pushed the play, rewind, and minus buttons,or still it doesn't power up, you've got a faulty regulator IC. It is the five pin chip colored black with the markings "PHK" (use a magnifying lens to confirm) located on the left besides the battery connector (facing up, with the earphone jack on the top). If you had micro soldering skills, then you can remove the chip and replace, if you can find a replacement...
Apr 03, 2007 | Mpio FL300 MP3 Player
Mpio FL300 MP3 Player Logo
125 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
