My Bissell ProHeat 2x is pouring water out of the bottom anytime it's turned on. I had it in the shop for no water, took it back again for the same problem, took it back again because it had no suction, finally took it apart and found the problem with the suction and fixed it myself. Worked fine for a day and now it is constantly leaking water, if it's turned on, and is useless for anything except for making a mess.
Took the unit apart and discovered my heater had small pinholes in the metal and they had put in silicone, instead of a gasket, which didn't seal. So much for the place I took it to "saving" my heater for me. I repaired it myself by getting a few o-rings and a seal from the hardware store. As for the "holes" in the bottom - a little marine fixative.
I can't tell if the "trigger" referred to in the manual is the one on the hose or the main...
(More)
I can't tell if the "trigger" referred to in the manual is the one on the hose or the main one on the machine.handle. I am trying to learn how to use the turboboost tool for spotting on the carpet. pro-heat 2x machinen
I'm having trouble inserting the new bladder. Everytime I get it in the bottom and put the valve in...
(More)
I'm having trouble inserting the new bladder. Everytime I get it in the bottom and put the valve in in pops back out. Is there another way to get it in?
