Question about Radio Shack Pro-97 Handheld Scanner
Stuck on scan mode
Scanner only scans , none of the buttons work not even the backlight. the keyboard does not work. the scanner has been unused for a month but has charged batteries. when turned on it goes to scan mode of channels programmed but nothing will change it . Cheers Noel
  • 204 Answers
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
Posted on Jan 26, 2008
How do you program a uniden bearcat scanner bc355c
Turn on the radio
Press the "band" button
Keep pressing the "band" button until you come within the parameters of the frequency that you want
Let the radio scan until it gets close to the actual frequency that you're looking for
Press the "hold" button and use the arrow "up" or "down" button till you lock in the correct frequency
Once you have the frequency locked in, press the "program" button
Press the "private" button
The unused channel will be flashing
Press the "program" button, this locks the frequency into that channel
Continue this process until all of the frequencies are loaded into the radio
Jan 05, 2011 | Uniden Radio Communications
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
After 2 yrs unused have decided to run in new dell
Did you plug in the scan unit and then installed the software?
If you did you will have to unplug or turn off your scanner then uninstall your software.
Reboot and the with the scanner turned off reinstall the software. If the install asks you to plug in your scanner, turn it on. If it asks you to reboot, then reboot. After rebooting, turn on the scanner then start the Easy Scan Utility. This should work.
It worked for me.
Jan 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
My uniden bc80xlt handheld scanner has lost all button functions. The radio still scans and picks up frequency broadcasts, but NONE of the buttons work. What is going on here?I have no" manual" function, I...
Sounds like you may have accidentally pressed the "LOCK" button. If there's a "key" icon showing, press the LOCK button at the bottom left of your keyboard, and hold it in until the icon disappears. In case you need it, here is a link to the operating manual for your scanner:
http://www.uniden.com/pdf/BC80XLTom.pdf
Nov 22, 2009 | Uniden BC80XLT Handheld Scanner
RS Pro 2020 Scanner won't come out of scan mode, pad ineffective
If you mean a Bearcat 2020 radio, then that unit is ancient, and I'm amazed that it still works. If you're only monitoring one frequency, you can get a really cheap scanner to do that and replace the 2020.
Aug 01, 2009 | Radio Shack Pro-2018 Scanner
Epson CX4200 scanner
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan.
Jul 10, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Scanner incorrectly reads frame position on film
Yes there is
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
Apr 27, 2007 | Epson Perfection 4990 Flatbed Scanner
Radio Shack Pro-97 Handheld Scanner Logo
343 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
