when I try to send a fax I recieve a message telling me the fax failed because there was no dial tone I do not have a seperate telephone line for the all in one as i have broad band
You cannot send a fax on a broadband connection, they should have given you a splitter, if not get one, the splitter is a small box like thing, it has two telephone sockets on one side and one socket on the other, the telephone line from the wall is connected on one side, on the other side you have to connect your adsl modem in one and your telephone in another socket, Usually the sockets have descriptions on them specifing which decive should be connected to the socket.
Now you should have a dial up modem(56Kbps internal or external modem) connect this modem to the socket which specifies, Telephone. Configure the modem. configure yor fax settings to use this modem. Now you can send your faxes.
If your ISP does not support dial-up then you cannot use it to send faxes.
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send
Machinery until you...
(More)
Machinery until you return to Dsna coude reset sharp ar-5316
How do I clear the BIOS on my s6500NX?
Usually this is done with a jumper change and battery...
(More)
Usually this is done with a jumper change and battery removal on a Dell.
Not sure how this one works.
Hi friend, My SONY VGC-LV250 only analog tuner can get signal,digital tuner does not work at all. Is...
(More)
Hi friend, My SONY VGC-LV250 only analog tuner can get signal,digital tuner does not work at all. Is there some setting wrong? I try my indoor antenna already. it works on other HDTV pretty well.
