i also have an acer aspire 5100 pc notebook. the hard drive has already been replaced and recently, the computer has started to freeze up again. i get the same error sometimes on start up but the numbers may be different. i get system bios v 2.70 buss 06 device 2 function 00 resource conflict PCI slot 03 bus 06 device 04 function 01 02 03 if anyone knows how i can fix this, pleas help. i havent really done much to resolve this issue because the computer usually freezes. sometimes it starts up normally, sometimes i get the error and sometimes it wants me to repair and run a system restore. i have done that.
I have my laptop ACER Aspire 5100 whitch i have problem with my network adapter card,
when i start the computer i get "2 beep" after that i get 3 errors :
I have exactly the same problem with an Acer Aspire 3100 (Same Bios as
5100). It seems to be related to the Atheros Wireless adapter (in slot
03?). You mentioned that your 5100 is still under warranty, mine
expire a couple of months ago) - what did Acer have to say about the
problem?
Try pressing F2 and look in the bios for a setting that says "Load Bios defaults". If you have any PCMCI cards inserted please remove them first and try a re-boot.
Have you added any new components on the PCI bus? If you have you need to make sure that the BIOS is allowed to reconfigure the interrupts. The device in slot 03 is conflicting with the integrated network controller hosted on the PCI bus. Remove the device in slot 3 and all should be well.
Most BIOS manufacturers allow the PC/Laptop to manage it's own interrupts, so ensure the device you've inserted allows for this. If it uses fixed interrupts this might be your problem.
A good manual should details the BIOS setting you can adjust in order to get the PCI controller happy again and allow the machine to POST correctly.
Regards,
Spare head 2
Rating Locked! (?) akwasi has rated this solution as Inappropriate
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Resource Conflict - PCI Network Controller in Slot 02:
Solution #3
posted on Aug 29, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
I was on this forum because I was having the same issue with a Toshiba A75 "Laptop", and I tried everything on here and on other forums and no luck. I actually just accessed the integrated wireless card panel from the bottom and removed it from its slot and disconnected the wireless wires connected and put it back on. So this has worked for me and my machine post perfectly now. Good luck to all and I hopefully this will be helpful too you.
Was this solution helpful? Show your Appreciation by rating it:
i have a 3102wlmi with a 5100 mb after my 1st mb took a dump on me, now i have the same problem, im running linux ubuntu since xp died on me with bsod, freezing and lan cable unplugged when it wasnt (got up to 6x a day!) now i have this problem however if i restart it a few times it goes away the pci conflict error is random on my computer though i tried moving around the pci boot order in the bios, f12>bios>startup>pci moved to slot 3
same as above.. nothing has helped fix. been in for reapairs once allready 6 montghs after i bought it. new 6 months down the line iots once again fracked. bad bad bad chipset
when I go to get on line with my other computer I get this message "resource conflict pci network controller in slot 3". I have unplugged my computer from the internet and I also tried restarting my net-gear. Nothing has helped.
