Mitsubishi WS-55809 55 in. Rear Projection Television
Problem for Mitsubishi WS-55809 55 in. Rear Projection Television
Picture blurred
By rmimsiii on Nov 03, 2009
Picture blurred
Clarification Request
Posted by SD Tech on Nov 03, 2009
Is picture 3D looking? colors out of place?
Solution #1
posted on Nov 03, 2009
Not Rated)
nileshsingh2
Rank: Wiz  Televisions & Videos  Expert
Rating: 84%, 68 votes
the best way to solve this problem is to resolder the whole pcb, board. heated areas should aslo be resoldered. this happens when a tv is being used for long time and it requires service again. by doing this it will be back to normal. if the problem dosnt solves, so some components such as capacitors, resistors or flyback transfomer should be changed if you are able to do this by yourself. crt socket in all projections needs to be checked, or take it to qualified service tech...and its worth to repair then buying new one.. any questions.. email.. nileshsingh2006@yahoo.com
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55809 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55809 55 in.
Do you recommend Mitsubishi WS-55809 55 in. Rear Projection Television?
Answer
Answer
Mitsu Medallion 1080HD rear projection TV. The color is bowing from top to bottom (2 colors). Also,... (More)
Answer
change convergence chips works great no curved lines but cant complety get all of green ghost out of... (More)
Answer
Trying to figure out to find my television code for media center Mitsuibishi Medallion CRT
Answer
when purchasing replacement convergence IC STK392-570 are they specific to the TV brand, I see... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55809 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
