Question about LG 42PX5D 42 in. Plasma HDTV
Grey shading on TV
The last couple of months I noticed that when the TV changes stations the right hand side keeps the images to some extent (ghost images) and leave the right hand side with an uneven grey image. Especially when watching a channel with a black background the right had side is totally grey.
I have read the manual and executed the steps to remove this (Whitewash) The result was negative. All the preventative steps were taken for e.g., no Still images, Cleaning and ventilation. The repair guys said that they could not detect any problems but obviously did not test this correctly. They stated that this could be my DSTV decoder? They stated that the Plasma’s motherboard is very complex. I personally think they don’t know how to fix this problem.
The TV still has 15 months of warranty left?
You expert advice would be appreciated.
    New Friend:
  • 60 Answers
If it's still under warranty call 800-243-0000 (LG customer service) and get them to send a technician out from a different shop. After 3 (or maybe it's on the 4th) repair attempts if it's not fixed you can ask for a different TV.
Posted on Jan 04, 2008
LG 55 UF6450 tv. The left half of the screen went to a weirdly shaded image over about 15 minutes and stayed that way.
The left side data buffer board is damaged, in most case is water leaked to the left side of the bottom screen.
Jan 12, 2018 | LG Televison & Video
Bought it used and the previous owner only used it in his salon. It worked fine for about a month and then I ended up with a line that went right to left and noticed two shaded boxes. I have been noti
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 02, 2014 | Vizio 55" VF550XVT1A 1080p 120Hz HDTV LCD
My t.v. picture was coming i ghost shade why?
If you are using antennae check the direction. If this is a cable input , then with a DVD , if all these show a ghost image, then the convergence of the TV section must be checked. Possible fault in the picture processing -( Y amp luminance)can lead to ghost images.
Jan 29, 2011 | Televison & Video
Grey Band and Ghosts on monitor
check the playback and other chips inside.. or try to change the setting menu the setting in your remote or manuall change
Jun 25, 2009 | Samsung SyncMaster 203B LCD Monitor
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Un-Clear picture
what types is it
Jun 06, 2008 | LG 42PC5D Television
Ghost images on the screen
sounds like the two stk392-560 ic's need to be changed, usually about $400 for the parts and labor
Mar 14, 2008 | Sony KP-51WS510 51" Rear Projection...
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
MItsubishi VS-4506R projection TV multiple b/w ghost images to the right
JAIL BARS IN PICTURE, CHECK C2B1 100 UFD 16V OFF PIN 2 IC202 ON THE MAIN PCB. If this does not help let me know.
Sep 11, 2007 | Televison & Video
LG 42PX5D 42 in. Plasma HDTV Logo
228 people viewed this question
Computer Repairing
Computer Repairing
