Question about Sony Cybershot S650 Digital Camera
Stuck on time menu
When I turn my camera on it is stuck on the clock set screen and making a repeated beeping noise. I can not take any pictures at all. Can anyone recommend anything
  • diener Jan 06, 2008
    no, the camera will not let me set time or get out of clock set, it is like it is frozen
Got exaxtly the same problem with mine. Cant get it fixed either!
Posted on Jan 06, 2008
  • cjfinno Jan 06, 2008
    Hi, just fixed mine by pressing the +/- sign on the left side of the cirlular button on the back. Just kept pressing it and it started moving. Hope that helps and sorts it out for ya.
  • 32 Answers
Stupid question, but here goes: Have you set the time? Once the time is set, the screen should go away.
If this isn't the case, then I suggest resetting the camera:
take out the batteries for about 5 minutes and then re-insert them.
Posted on Jan 04, 2008
How to set self timer for D90
Instructions for this are on Page 179 of the D-90 users manual. First go to the menu and select the custom settings menu then scroll down to "timers/AF Lock."
Select this then select the number of shots you want the camera to take at one time on the self timer setting. Exit the menu.
Then go to the top of the camera and find the little button to the right of the control panel which contains a series of stacked rectangles.
Depress this button (camera must be on) and the control panel will clear. Rotate the wheel on the back of the camera while holding the button down until you see a little clock symbol.
If you have set it in the menu to take only one shot, you will see only the little clock. If you have set it to take multiple shots you will see the series of stacked rectangles next to the little clock.
Depress the shutter fully then walk or run to get in the picture. Just before the picture shoots, the autofocus light will flash warning you that the picture is about to be taken. The camera will shoot in the amount of time you have selected in the menu.
If you want to shoot another delayed shutter picture, repeat the procedure using the button and wheel.
May 10, 2013 | Nikon D90 Digital Camera with 18-105mm...
My camera makes a beeping noise EVERY time I push a button on it! It's really annoying! How do I turn the beeping noise off???
Tap MENU to bring up the menu screen. Tap the wrench tab to access the Setup menu. Scroll down if needed, and select "Sound Settings." Turn off the "Button Sound" and, if desired, the "Shutter Sound."
This is described in the "Sound Settings" subsection of the "Setup Menu" section of the manual (page 148 in my copy).
Apr 13, 2011 | Nikon Coolpix S4000 Digital Camera
How do I set the time and date on a Panasonic DMC-LZ4
1. Press the menu/set button. This will bring up a menu.
2. Press arrow left (the button left of the menu/set button).
3. Press arrow down (the button below the menu/set button). This will select the setup menu (so, a wrench icon should be brighter than an icon of a camera).
4. Press arrow up or down (these buttons are above and below the menu/set button respectively) to highlight clock set.
5. When clock set is highlighted press the right arrow button (button right of the menu/set button).
6. Press right or left to select what settings you want to change.
7. Press up or down to get numbers according as you want them.
8. Repeat 6. and 7. as desired.
9. Press menu/set several times to exit menu options.
Feb 28, 2011 | Panasonic Lumix DMC-LS80 Digital Camera
My Olympus Camedia C-750 will not turn on. When I start it, the screen looks normal but then goes blank. it stays lighted and then beeps several times then makes a noise like a picture has been taken,...
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
Sep 05, 2017 | Olympus Camedia C-750 Ultra Zoom Digital...
How do you stop the beeping sound when you press the menu biuttons etc e.g. like to view your pictures etc on the SONY Cyber-shot DSC-W350 ? it is really annoying to hear the beeping every time you...
I have a W560, but maybe it's the same on your camera. It was driving me insane as well. On my camera, I went to the menu, under Main Settings there was something called "Beep." It gave the options of "Shutter, High, Low, and Off." If I chose Shutter, then it keeps a shutter-like noise when you take a picture but turns off the annoying beep whenever you push any other button. I assume if you choose Off it will turn off all noises.
Hope that helps!
Jan 07, 2011 | Sony Cyber-shot® DSC-W50 Digital Camera
DXG-308 Digital Camera
To activate the timer, press the menu button (round center button in middle of arrows) then press the right arrow once until you see a cirlce with a line through it. Then press the down or up arrow and it will turn it on. You know this when the line disappears. Then press the menu button again and you are set. You will see the timer clock on the display screen. To turn it off just repeat the steps.
Dec 26, 2008 | DXG Technology DXG-308 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Wrong date and/or time
Whenever you change the batteries in your camera you need to reset the clock. You can use the LCD screen Settings menu or set the camera's clock from your computer.
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Sony Cybershot S650 Digital Camera Logo
199 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
