Philips MX6050D System
Problem for Philips MX6050D System
The tray does not open
By vitalymosk on Nov 03, 2009
The DVD tray does not open
Solution #1
posted on Nov 04, 2009
Not Rated)
lock123
Rank: Guru
Rating: 89%, 91 votes
Hello
Do you know if there might be a cd stuck in the trey, if so, here is hoe you fix this.
Take a pin and push it into the small hole near the eject button. Push it in until you feel a resistance to movement of the pin, while doing this, gently pull out the try.
If there is no cd stuck in the player, the problem is the little rubber band which drives out the trey. If this is the problem, you should hear a noise if you press the eject button. It is really cheap to fix. Hope this can help you.
Best regards
Andrea
Was this helpful?
Yes
No
Popular Solutions for Philips MX6050D System
Questions and Unsolved Problems for Philips MX6050D System
Do you recommend Philips MX6050D System?
Answer
Answer
I want a new dvd player that will connect to the easy-fit connectors. I currently have a Philips... (More)
Answer
Hi i'm looking for a philips remote control for my surround sound(mx6050d) i live in Toronto Canada... (More)
Answer
I can play a dvd for a while but all of a sudden there will be loud pop and then no sound. If I turn... (More)
Answer
When you insert a DVD in the machine, it reads the disc ok. When it starts playing, you have sound,... (More)
Answer
I own a Philips MX6050 home theater system; I also own a ILO MTS stereo TV. I need to make my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips MX6050D System:
Top Home Theater System Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Home Theater System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
