Sony Cyber-shot DSC-W50 Digital Camera
Problem for Sony Cyber-shot DSC-W50 Digital Camera
I have a sony cyber-shot 12.1 mega pixel and when
By rhodes_chels on Nov 03, 2009
I have a sony cyber-shot 12.1 mega pixel and when i try to zoom the display tells me to turn of the power and on again. but nothing changes. i still can't zoom. i can zoom when looking at pictures i've already taken.
Solution #1
posted on Nov 03, 2009
Not Rated)
StephanSA
Rank: Guru  Sony Cameras & Camcorders  Expert
Rating: 93%, 184 votes
Hello
This either means that something is jamming the lens , or that the lens sensor is faulty. This is a very , if not the most common problem with modern digital camera's.
Most of the time the problem is that sand , dirt and grit gets lodged in the camera lens barrel thus keeping it from extending properly but could also be caused by a drop or a hard knock on the camera.
Firstly , the odds are not with you on a DIY fix so don't be disappointed when the following steps do not work.Nevertheless , some people have fixed their camera's using the following steps.
Use these at own risk as it may further damage the camera.
Firstly try charging your batteries overnight and then try the camera again tomorrow.
Try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
These 3 options provide your camera with more power available to the extension mechanism which could overcome some of the particles that are lodged in there if there are any.
Try using compressed air (best is a clean air can bought at a electronics store) and blow between the lens and the casing. This should help dislodge some of the particles.
Look at the lens , and if some of the lens 'circles' are misaligned or not concentric then try wiggling it (while holding camera lens down) so that some of the particles can escape. Also try moving the lens away from the side with the biggest gap (also upside down)
Try gently pushing or pulling the lens when it tries to extend but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
As a last resort if you decide to replace the camera try hitting the camera near the lens with increasing force with the palm of your hand. Between each hit , try using it again.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise works. Good luck and don't hesitate to contact me if you need further assistance or information.
Regards
Stephan
Comments:
Nov 04, 2009
- Hello
Regards
Stephan
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-shot DSC-W50
Questions and Unsolved Problems for Sony Cyber-shot DSC-W50
Do you recommend Sony Cyber-shot DSC-W50 Digital Camera?
Answer
Answer
why can't my camera take shots and the zoom lens keeps on working
Answer
When I turn on my camera the message acces appear on the screen and nothing happen
Answer
does not shoot any photos, only says turn of and on camera
Answer
Although my camera says the flash is on, when I take a picture, it does not flash and the picture... (More)
Answer
The lens won't come all the way out- it makes clicking noises like it wants to and kind of bounces... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Cyber-shot DSC-W50...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
