Intel 82566dc... hi im trying to take aghost image to our servers of this board but cant seem to locate a ndis2 boot disk is there another way i can do this..im using ghost solotuions v2... lan driver free downlode (intal orignal)
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there,
If your board is Intel, you can download drivers from there, using the code number of the board, or name.
it is more easy!
www.intel.com
Posted on Jan 05, 2008
Cloned Drive won't boot on Dell 1600SC
If you are using an image made from the IBM and it has a different processor and the board specs are different that can cause the drive not to boot it will act like it is then go into a perpetual boot. I would try to re image it again to insure that is ok on the drive also check the board If one is and AMD and the other an Intel then that would be part of the problem.
Aug 05, 2017 | Dell PowerEdge 1600SC Server
Boot cd
http://www.todaydown.com/intel-server/intel-server-board-se7500wv2se7500wv2-ssu-package-1-release-2-version-1-r-2-se7500wv2_1r2-exe.html
May 27, 2013 | Intel Server Chassis SR2300 and Server...
Hi guies the windows srever 2003 files in my hp ml370 is corrupt and i tried to fix the prblem by format one hard disk partition in my scasi disks array and installing win srv 2003 on it but whe i log on...
HP SmartStart CD x32
The utility to use to set up the ML370 g3 server is the SSCD (smart start cd) this is a guided installation cd that will help you set up the array, install drivers and diagnostic utilities and after that
will request the windows cd so that you can finish the installation.
instructions:
1. download SSCD from here
2. extract the zip file
3. burn the ISO image to a cd
4. boot the server to the cd
5. choose from the main menu the option "Deploy server"
6. follow the wizard
Oct 26, 2010 | HP Compaq ProLiant ML370 G3 Server
Emachine NAV51 won't start up. It keeps showing this: Intel UNDI PXE_2.1 (Build 082)_Copyright(c) 1997-2000 Intel Corporation_For Atheros PCIE Ethernet Controller_V2.0.0.9 (05/08/09)_Check cable...
Long answer:
Your computer tries to "boot" from various devices:
* the 'A:' diskette drive
* the CD-ROM drive
* a bootable image on a USB memory-stick
* via the network-adapter, if there is a "boot-server" somewhere on your local network.
So, enter BIOS SETUP, and check that your disk-drive is one of "enabled" boot devices. Also, check that the disk-drive is "detected" by the BIOS.
If your disk-drive is not connected, or not responding, and there is nothing in the 'A:' drive and nothing in the CD-ROM drive, then the PXE (Pre eXecution Environment) will try to "talk" to a boot-server on your network. If no such server is found, you get the "check cable connection" message, and you are prompted to put some "bootable" media into the 'A:' drive or the CD-ROM drive.
Short answer: your disk-drive has "died". You need to replace it, and to install Windows onto the new disk-drive.
I hope that you recently made a good "backup" of all your data files!
Oct 20, 2010 | E-Machines eMachines Desktop PC
Intel d815/eea2 powers up but does not boot
hi im josh in cebu phils. if it turns on but not boot. the problem is no set boot sector is selected. friend try to enter bios set up and then go to boot menu. then select hard drive to boot first.then save the changes then restart the pc. if nothing improves open your pc check the ide or sata cable if it is ok.no cut not losen.try to tighten firmly first then turn on your pc. if it doesnt work the same try to change the ide/sata cable and dont forget to give power supply on your hard disk.ok. good luck
Feb 20, 2009 | Intel Desktop Board D815EEA2 Universal...
Ghost array0 over to newly setup array1 problems
I should assume the CD drive is SCSI? What sequence is it set to come up in? Set it at 2 if possible. Have you checked, or better yet replaced the CD drive? Will it boot with ANYTHING else?
That Hiren's CD is not uuummm, kosher? People having problems booting with it and all, plus the utilities may not have full function anyway. No matter what, you will need to f/disk the destination drive. You will still need the CD drive to install the program too.
Backup software will still make an exact copy of your drive also. You might want to consider a little better product, especially concerning disaster recovery. not to get off topic but, a quote from J. Bolton on backup & recovery
"What will you do if a user overwrites a 1000page doc with a blank file with the same name? What will you do if one of multiple server apps goes bonkers? If the mainboard dies how will imaging get your system back? Do you stock a spare board so the image restore will work on the exact same hardware? After a system crash, Acronis True Image Enterprise Server allows you to perform a full system restore, a bare-metal restore or just a restore of individual files and folders.
Complete system restoration can be performed to an existing system, to a new system with different hardware or to a virtual machine. You could setup a whole new system and dump the image on that.
Dec 04, 2007 | Dell PowerEdge 2600 Server
Intel 82566dc...
I'm not sure that Ghost would be able to save an image over the network even if you could find a ndis2 boot disk. You might be better off ghosting the image to local storage (external USB HDD, or connecting a bare drive internally), which you then connect to a working machine to upload the image to the network?
Of course, you'd need to do the reverse to restore it to the same machine - though there is no reason you would not be able to restore the image to a bare drive on any system, and then install that drive is the boot device in the original system.
Nov 30, 2007 | Intel D915GAV Motherboard
Computers & Internet Logo
102 people viewed this question
Alun Cox
David Payne
David Payne
